Aller au contenu principal
Dell Inspiron 1428 Display Assembly Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 1428 Display Assembly Replacement, Routing the Cables: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Make note of the Mini-Card antenna cables routing and remove the cables from the routing guides.
  2. Dell Inspiron 1428 Display Assembly Replacement, Remove the Screws: étape 2, image 1 de 1
    • Remove the four screws that secure the display assembly to the computer base.
  3. Dell Inspiron 1428 Display Assembly Replacement, Dislodging the Cables: étape 3, image 1 de 1
    • Make note of the Mini-Card antenna cable routing and carefully dislodge the antenna cables from the cable routing slot on the computer. Pull the cables away, so that they are clear of the palm rest.
  4. Dell Inspiron 1428 Display Assembly Replacement, Disconnecting the cables: étape 4, image 1 de 1
    • Disconnect the display cable, inverter board cable, camera cable, and microphone cables from the respective system board connectors.
  5. Dell Inspiron 1428 Display Assembly Replacement, Remove the Cables: étape 5, image 1 de 1
    • Remove the cables from their routing guides.
  6. Dell Inspiron 1428 Display Assembly Replacement, Remove the Screws: étape 6, image 1 de 1
    • Remove the two screws that secure the display assembly to the computer base.
  7. Dell Inspiron 1428 Display Assembly Replacement, Lifting the Display Assembly: étape 7, image 1 de 1
    • Lift the display assembly off the computer.
  8. Dell Inspiron 1428 Display Assembly Replacement, Placing the Display Assembly: étape 8, image 1 de 1
    • Place the NEW display assembly in position and replace the two screws that secure the display assembly to the computer base.
  9. Dell Inspiron 1428 Display Assembly Replacement, Routing the Cable: étape 9, image 1 de 1
    • Route all the cables through the routing guides.
  10. Dell Inspiron 1428 Display Assembly Replacement, Connecting the Cables: étape 10, image 1 de 1
    • Connect the display cable, inverter board cable, and the camera cable to their respective system board connectors.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 549 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 147
