Aller au contenu principal
Dell Inspiron 1440 CD Drive Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 1440 CD Drive Replacement, Keyboard: étape 1, image 1 de 2 Dell Inspiron 1440 CD Drive Replacement, Keyboard: étape 1, image 2 de 2
    • Take off the plastic strip with the speaker cover above the keyboard using an opening tool.
    • Once it pops out, pull it off.
  2. Dell Inspiron 1440 CD Drive Replacement: étape 2, image 1 de 1
    • Remove the screws at the top of the keyboard.
  3. Dell Inspiron 1440 CD Drive Replacement: étape 3, image 1 de 1
    • Lift from the top part of the keyboard and pull out.
  4. Dell Inspiron 1440 CD Drive Replacement, CD Drive: étape 4, image 1 de 2 Dell Inspiron 1440 CD Drive Replacement, CD Drive: étape 4, image 2 de 2
    • Remove all of the 6 mm screws on the bottom of the laptop.
    • There are some that go along the edge and some that are surrounding and underneath the middle plate.
  5. Dell Inspiron 1440 CD Drive Replacement: étape 5, image 1 de 2 Dell Inspiron 1440 CD Drive Replacement: étape 5, image 2 de 2
    • Remove the 6 mm screws that are in the silver metal plate under the keyboard.
    • Disconnect any wires that are attached to the metal plate.
  6. Dell Inspiron 1440 CD Drive Replacement: étape 6, image 1 de 2 Dell Inspiron 1440 CD Drive Replacement: étape 6, image 2 de 2
    • Once all of the screws are out of the silver plate and the bottom of the laptop, pull the silver plate, which is attached to the silver plastic on top, off of the laptop.
  7. Dell Inspiron 1440 CD Drive Replacement: étape 7, image 1 de 3 Dell Inspiron 1440 CD Drive Replacement: étape 7, image 2 de 3 Dell Inspiron 1440 CD Drive Replacement: étape 7, image 3 de 3
    • Remove the 3 mm screws from the CD drive.
    • Push out on the top of the CD drive to the right.
    • Pull the CD drive all the way out.
Tyler Lyons
Membre depuis le 11/05/19
452 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G3, Barthe Fall 2019 Membre de l'équipe UMass Dartmouth, Team S1-G3, Barthe Fall 2019
UMASSD-BARTHE-F19S1G3
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 16
Total : 438
