Aller au contenu principal
Dell Inspiron 1440 Touch Pad Buttons Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 1440 Touch Pad Buttons Replacement, Keyboard: étape 1, image 1 de 2 Dell Inspiron 1440 Touch Pad Buttons Replacement, Keyboard: étape 1, image 2 de 2
    • Take off the plastic strip with the speaker cover above the keyboard using an opening tool.
    • Once it pops out, pull it off.
  2. Dell Inspiron 1440 Touch Pad Buttons Replacement: étape 2, image 1 de 1
    • Remove the screws at the top of the keyboard.
  3. Dell Inspiron 1440 Touch Pad Buttons Replacement: étape 3, image 1 de 1
    • Lift from the top part of the keyboard and pull out.
  4. Dell Inspiron 1440 Touch Pad Buttons Replacement, Touch Pad Buttons: étape 4, image 1 de 2 Dell Inspiron 1440 Touch Pad Buttons Replacement, Touch Pad Buttons: étape 4, image 2 de 2
    • Remove all of the 6 mm screws on the bottom of the laptop.
    • There are some that go along the edge and some that surrounding and underneath a middle plate.
  5. Dell Inspiron 1440 Touch Pad Buttons Replacement: étape 5, image 1 de 2 Dell Inspiron 1440 Touch Pad Buttons Replacement: étape 5, image 2 de 2
    • Remove the 6 mm screws that are in the silver metal plate under the keyboard.
    • Disconnect any wires that are attached to the metal plate.
  6. Dell Inspiron 1440 Touch Pad Buttons Replacement: étape 6, image 1 de 2 Dell Inspiron 1440 Touch Pad Buttons Replacement: étape 6, image 2 de 2
    • Once all of the screws are out of the silver plate and the bottom of the laptop, pull silver plate, which is attached to the silver plastic on top, off of the laptop.
  7. Dell Inspiron 1440 Touch Pad Buttons Replacement: étape 7, image 1 de 2 Dell Inspiron 1440 Touch Pad Buttons Replacement: étape 7, image 2 de 2
    • Flip over the silver plate, and remove the 3 mm screw attached the buttons.
    • Remove the ribbon cables that are also attached.
  8. Dell Inspiron 1440 Touch Pad Buttons Replacement: étape 8, image 1 de 1
    • Remove the buttons.
Tyler Lyons
Membre depuis le 11/05/19
452 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G3, Barthe Fall 2019 Membre de l'équipe UMass Dartmouth, Team S1-G3, Barthe Fall 2019
UMASSD-BARTHE-F19S1G3
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 13
Total : 363
