Aller au contenu principal
Dell Inspiron 14R SE 7420 Display Assembly Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Close the Display: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • Close the display and turn the computer over.
  2. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Remove the Screws: étape 2, image 1 de 1
    • Remove the screws that secure the display assembly to the computer base.
  3. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Open the Display: étape 3, image 1 de 1
    • Turn the computer over and open the display as far as possible.
  4. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Disconnecting the Antenna Cables: étape 4, image 1 de 1
    • Disconnect the antenna cables from the connectors on the Mini-Card.
  5. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Remove the Screws: étape 5, image 1 de 1
  6. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Lifting the Display Assembly: étape 6, image 1 de 1
    • Lift the display assembly off the computer base.
  7. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Placing the Display Assembly: étape 7, image 1 de 2 Dell Inspiron 14R SE 7420 Display Assembly Replacement, Placing the Display Assembly: étape 7, image 2 de 2
    • Place the display assembly in position and replace the screws that secure the display assembly to the computer base.
  8. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Connecting the Antenna Cables: étape 8, image 1 de 1
    • Connect the antenna cables to the connectors on the Mini-Card.
  9. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Close the Display: étape 9, image 1 de 1
  10. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Replace the Screws: étape 10, image 1 de 1
    • Replace the screws that secure the display assembly to the computer base.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 522 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 14
Total : 397
