Aller au contenu principal
Dell Inspiron 14R SE 7420 Memory Modules Replacement
  1. Dell Inspiron 14R SE 7420 Memory Modules Replacement, Popping up the Memory Module: étape 1, image 1 de 2 Dell Inspiron 14R SE 7420 Memory Modules Replacement, Popping up the Memory Module: étape 1, image 2 de 2
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory-module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
  2. Dell Inspiron 14R SE 7420 Memory Modules Replacement, Remove the Memory Module: étape 2, image 1 de 1
    • Remove the memory module from the memory-module connector.
  3. Dell Inspiron 14R SE 7420 Memory Modules Replacement, Align the Notch: étape 3, image 1 de 1
    • Align the notch on the NEW memory module with the tab on the memory-module connector.
  4. Dell Inspiron 14R SE 7420 Memory Modules Replacement, Sliding the Memory Module: étape 4, image 1 de 1
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 309 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 984 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 120
