Aller au contenu principal
Dell Inspiron 14z Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 14z Hard Drive Replacement, Hard Drive: étape 1, image 1 de 3 Dell Inspiron 14z Hard Drive Replacement, Hard Drive: étape 1, image 2 de 3 Dell Inspiron 14z Hard Drive Replacement, Hard Drive: étape 1, image 3 de 3
    • Here is a Dell Inspiron 14z N411z with a defective hard drive.
    • On the back side is only one cover for the hard drive as well as the memory module.
    • Remove the Phillips screw on the bottom right corner of the cover.
  2. Dell Inspiron 14z Hard Drive Replacement: étape 2, image 1 de 3 Dell Inspiron 14z Hard Drive Replacement: étape 2, image 2 de 3 Dell Inspiron 14z Hard Drive Replacement: étape 2, image 3 de 3
    • Use a plastic opening tool to unsnap the cover from the back case.
    • Move the tool gently along the corner of the cover.
    • The screw that holds the cover on, has a spring clip that keeps the screw attached to the cover. during removal of the screw, this clip might come off.
  3. Dell Inspiron 14z Hard Drive Replacement: étape 3, image 1 de 3 Dell Inspiron 14z Hard Drive Replacement: étape 3, image 2 de 3 Dell Inspiron 14z Hard Drive Replacement: étape 3, image 3 de 3
    • With the removal of the cover, the hard drive is immediately visible. Remove the four screws securing the hard drive bracket.
    • Slide the hard drive to the opposite end of the connector. This will free the connection.
  4. Dell Inspiron 14z Hard Drive Replacement: étape 4, image 1 de 3 Dell Inspiron 14z Hard Drive Replacement: étape 4, image 2 de 3 Dell Inspiron 14z Hard Drive Replacement: étape 4, image 3 de 3
    • Pull gently on the black tab on the hard drive. This will remove the drive and caddy from the computer.
    • Remove the two Phillips screws on the right side,
    • and the two Phillips screws on the left side.
  5. Dell Inspiron 14z Hard Drive Replacement: étape 5, image 1 de 1
    • The hard drive is now removed from the caddy and the replacement can be installed.
2 autres ont terminé cette réparation.
oldturkey03
Membre depuis le 09/29/10
778 207 Réputation
118 tutoriels rédigés
Équipe
Global Fixers Membre de l'équipe Global Fixers
Community
31 membres
520 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 3
Total : 12,769
