Aller au contenu principal
Dell Inspiron 14z-5423 Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 14z-5423 Hard Drive Replacement, RAM: étape 1, image 1 de 2 Dell Inspiron 14z-5423 Hard Drive Replacement, RAM: étape 1, image 2 de 2
    • Close the display and turn over the computer.
    • Make sure your device is powered down and unplugged before beginning the replacement.
  2. Dell Inspiron 14z-5423 Hard Drive Replacement: étape 2, image 1 de 1
    • Use a J0 bit tipped screwdriver to unscrew the one 6 mm Phillips screw on the RAM cover.
  3. Dell Inspiron 14z-5423 Hard Drive Replacement: étape 3, image 1 de 2 Dell Inspiron 14z-5423 Hard Drive Replacement: étape 3, image 2 de 2
    • Lightly lift the RAM cover up and at an angle, away from the computer.
  4. Dell Inspiron 14z-5423 Hard Drive Replacement: étape 4, image 1 de 2 Dell Inspiron 14z-5423 Hard Drive Replacement: étape 4, image 2 de 2
    • Use your fingers to carefully pull the securing clips on the RAM away from each other.
    • The RAM should pop up when the clips are released.
  5. Dell Inspiron 14z-5423 Hard Drive Replacement: étape 5, image 1 de 2 Dell Inspiron 14z-5423 Hard Drive Replacement: étape 5, image 2 de 2
    • Remove the popped up RAM by pulling it away from the connection.
    • If it does not pop up pry it out in a steady and straight direction.
  6. Dell Inspiron 14z-5423 Hard Drive Replacement, Optical Drive: étape 6, image 1 de 2 Dell Inspiron 14z-5423 Hard Drive Replacement, Optical Drive: étape 6, image 2 de 2
    • Slide the CD/DVD drive on the side of the laptop out using your fingers.
    • Using a J0 bit screwdriver, unscrew the one 2 mm Phillips screw.
    • You only need to unscrew this screw if you are using this as a prerequisite guide.
  7. Dell Inspiron 14z-5423 Hard Drive Replacement, Keyboard: étape 7, image 1 de 3 Dell Inspiron 14z-5423 Hard Drive Replacement, Keyboard: étape 7, image 2 de 3 Dell Inspiron 14z-5423 Hard Drive Replacement, Keyboard: étape 7, image 3 de 3
    • Lift the plastic yellow flap on the system board.
    • Use the J0 Bit screwdriver to remove the one 6 mm Phillips screw in center of the system board that is connected to the keyboard.
  8. Dell Inspiron 14z-5423 Hard Drive Replacement: étape 8, image 1 de 1
    • Flip over the computer and open the display.
  9. Dell Inspiron 14z-5423 Hard Drive Replacement: étape 9, image 1 de 2 Dell Inspiron 14z-5423 Hard Drive Replacement: étape 9, image 2 de 2
    • Insert a spudger next to the plastic indents located at the top of the keyboard and gently pry to release the securing clips.
    • Lift the keyboard off of the computer.
    • Be careful not to tear the ribbon that attaches the back of the keyboard to the computer when lifting it.
  10. Dell Inspiron 14z-5423 Hard Drive Replacement: étape 10, image 1 de 2 Dell Inspiron 14z-5423 Hard Drive Replacement: étape 10, image 2 de 2
    • Flip the keyboard over onto the palm-rest assembly.
  11. Dell Inspiron 14z-5423 Hard Drive Replacement: étape 11, image 1 de 3 Dell Inspiron 14z-5423 Hard Drive Replacement: étape 11, image 2 de 3 Dell Inspiron 14z-5423 Hard Drive Replacement: étape 11, image 3 de 3
    • Flip the little black securing bar near the base of the ribbon with a spudger to release the ribbon from the computer.
  12. Dell Inspiron 14z-5423 Hard Drive Replacement, Palm Rest Assembly: étape 12, image 1 de 1
  13. Dell Inspiron 14z-5423 Hard Drive Replacement: étape 13, image 1 de 3 Dell Inspiron 14z-5423 Hard Drive Replacement: étape 13, image 2 de 3 Dell Inspiron 14z-5423 Hard Drive Replacement: étape 13, image 3 de 3
    Outil utilisé dans cette étape :
    • Remove all 7 rubber screw caps with tweezers.
    • Use a J0 Bit tipped screwdriver unscrew the seven 6 mm Phillips screws on the back casing of the laptop.
  14. Dell Inspiron 14z-5423 Hard Drive Replacement: étape 14, image 1 de 2 Dell Inspiron 14z-5423 Hard Drive Replacement: étape 14, image 2 de 2
    • Flip the computer over and open the display.
    • Pull on the blue tabs to disconnect the palm rest assembly from the computer.
  15. Dell Inspiron 14z-5423 Hard Drive Replacement: étape 15, image 1 de 1
    • Use J0 Bit screwdriver to remove all four 6 mm Phillips screws.
  16. Dell Inspiron 14z-5423 Hard Drive Replacement: étape 16, image 1 de 3 Dell Inspiron 14z-5423 Hard Drive Replacement: étape 16, image 2 de 3 Dell Inspiron 14z-5423 Hard Drive Replacement: étape 16, image 3 de 3
    • Gently wedge the nylon spudger underneath the palm-rest assembly to release the latches.
    • Continue this process on all sides of the computer edges until the assembly pulls off.
    • Remove the palm rest assembly.
    • If you have difficulty lifting up the assembly, you might not have taken out all 7 screws on the bottom of the computer.
  17. Dell Inspiron 14z-5423 Hard Drive Replacement, Battery: étape 17, image 1 de 2 Dell Inspiron 14z-5423 Hard Drive Replacement, Battery: étape 17, image 2 de 2
    • Use a J0 Bit screwdriver to remove the two 6 mm Phillips screws securing the battery located near the bottom of the laptop.
  18. Dell Inspiron 14z-5423 Hard Drive Replacement: étape 18, image 1 de 3 Dell Inspiron 14z-5423 Hard Drive Replacement: étape 18, image 2 de 3 Dell Inspiron 14z-5423 Hard Drive Replacement: étape 18, image 3 de 3
    • Lift the tiny black tab and pull the battery out at a slight angle.
  19. Dell Inspiron 14z-5423 Hard Drive Replacement, Hard Drive: étape 19, image 1 de 2 Dell Inspiron 14z-5423 Hard Drive Replacement, Hard Drive: étape 19, image 2 de 2
    • Lift up the bottom of the hard drive which is located at the bottom of the laptop.
    • Gently pull the drive out at an angle using your fingers.
  20. Dell Inspiron 14z-5423 Hard Drive Replacement: étape 20, image 1 de 1
    • Using a J0 bit tipped screwdriver, remove the four 3 mm black screws on both sides of the hard drive bracket.
  21. Dell Inspiron 14z-5423 Hard Drive Replacement: étape 21, image 1 de 1
    • Slide the hard drive out of the bracket.
16 autres ont terminé cette réparation.
Brittany
Membre depuis le 09/12/16
917 Réputation
4 tutoriels rédigés
Équipe
CSU Fullerton, Team 2-2, Bruce Fall 2016 Membre de l'équipe CSU Fullerton, Team 2-2, Bruce Fall 2016
CSUF-BRUCE-F16S2G2
5 membres
11 tutoriels rédigés
5 commentaires
Worked perfectly, right down to the last screw under the memory.
Michael Maxson - Réponse
You are a lifesaver! Thank you.
hiddenpcmaster - Réponse
Thanks! These instructions worked very well for me, and I performed my battery and disk upgrades successfully!
ericfogleman - Réponse
This guide was straight forward and gave me the exact step by step instructions! Good job!
Arun Venkiteswaran - Réponse
Even a dumbass as myself would understand this and follow through. Thank you author!!!
Fon Nguti Abraham - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 11
30 derniers jours : 23
Total : 6,698
