Aller au contenu principal
Dell Inspiron 14z-5423 Memory Modules Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 14z-5423 Memory Modules Replacement, Close the Display: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin". After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • Close the display and turn the computer over.
  2. Dell Inspiron 14z-5423 Memory Modules Replacement, Loosen the Screw: étape 2, image 1 de 1
    • Loosen the captive screw that secures the memory-module cover to the computer base.
  3. Dell Inspiron 14z-5423 Memory Modules Replacement, Lifting the Cover: étape 3, image 1 de 1
    • Using your fingertips, lift and slide the memory-module cover out of the slots on the computer base.
  4. Dell Inspiron 14z-5423 Memory Modules Replacement, Remove the Memory Module: étape 4, image 1 de 1
    • Remove the memory module from the memory-module connector.
  5. Dell Inspiron 14z-5423 Memory Modules Replacement, Align the Notch: étape 5, image 1 de 1
    • Align the notch on the NEW memory module with the tab on the memory-module connector.
  6. Dell Inspiron 14z-5423 Memory Modules Replacement, Sliding the Memory Module: étape 6, image 1 de 1
    • Slide the memory module firmly into the connector at a 45-degree angle and press the memory module down until it clicks into place.If you do not hear the click, remove the memory module and reinstall it.
  7. Dell Inspiron 14z-5423 Memory Modules Replacement, Slide the Tabs: étape 7, image 1 de 1
    • Slide the tabs on the memory-module cover into the slots on the computer base and snap the memory-module cover into place.
  8. Dell Inspiron 14z-5423 Memory Modules Replacement, Tighten the Screw: étape 8, image 1 de 1
    • Tighten the captive screw that secures the memory-module cover to the computer base.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 555 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 3
Total : 232
