Aller au contenu principal
Dell Inspiron 15 3541 Keyboard Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15 3541 Keyboard Replacement, Battery: étape 1, image 1 de 2 Dell Inspiron 15 3541 Keyboard Replacement, Battery: étape 1, image 2 de 2
    • Make sure your laptop is powered off completely and is not connected to the charger.
    • Close the laptop and place it so that the back of the screen is lying flat on your work surface.
    • Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
  2. Dell Inspiron 15 3541 Keyboard Replacement: étape 2, image 1 de 1
    • Lift the battery at an angle using your fingertips and remove it from the laptop.
    • Press and hold the power button for 5 seconds. This ensures that any remaining power will drain out of the computer.
  3. Dell Inspiron 15 3541 Keyboard Replacement, Keyboard: étape 3, image 1 de 2 Dell Inspiron 15 3541 Keyboard Replacement, Keyboard: étape 3, image 2 de 2
    • Open the laptop and fully extend the screen.
    • Using the nylon spudger, pry the keyboard off the laptop body.
    • Using your hands, remove the keyboard from the body and place it facedown on the track pad. There will be a cord connecting the laptop and the keyboard: keep this cord intact.
  4. Dell Inspiron 15 3541 Keyboard Replacement: étape 4, image 1 de 2 Dell Inspiron 15 3541 Keyboard Replacement: étape 4, image 2 de 2
    • Unhook the connector and you can now remove the keyboard from the laptop
    • If your version of this laptop has a backlit keyboard, there will be two connectors; the one highlighted orange will also have to be removed.
8 autres ont terminé cette réparation.
Allison
Membre depuis le 03/04/16
571 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 5-8, Landers Spring 2016 Membre de l'équipe UMass Dartmouth, Team 5-8, Landers Spring 2016
UMASSD-LANDERS-S16S5G8
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 20
30 derniers jours : 29
Total : 3,526
