Aller au contenu principal
Dell Inspiron 15 3568 Display Assembly Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15 3568 Display Assembly Replacement, Open the Display: étape 1, image 1 de 1
  2. Dell Inspiron 15 3568 Display Assembly Replacement, Note the Antenna Cable: étape 2, image 1 de 1
    • Note the antenna cable routing and remove the antenna cables from its routing guides on the computer base.
  3. Dell Inspiron 15 3568 Display Assembly Replacement, Remove the Cable: étape 3, image 1 de 1
    • Note the display cable routing and remove the cable from its routing guides on the computer base.
  4. Dell Inspiron 15 3568 Display Assembly Replacement, Remove the Screws: étape 4, image 1 de 1
    • Remove the screws that secure the display hinges to the computer base.
  5. Dell Inspiron 15 3568 Display Assembly Replacement, Lifting the Display Assembly: étape 5, image 1 de 1
    • Carefully lift the display assembly off the computer base.
  6. Dell Inspiron 15 3568 Display Assembly Replacement, Align the Screw Holes: étape 6, image 1 de 1
    • Align the screw holes on the display hinges with the screw holes on the computer base.
  7. Dell Inspiron 15 3568 Display Assembly Replacement, Replace the Screws: étape 7, image 1 de 1
    • Replace the screws that secure the display hinges to the computer base.
  8. Dell Inspiron 15 3568 Display Assembly Replacement, Route the Display Cable: étape 8, image 1 de 1
    • Route the display cable through its routing guides on the computer base.
  9. Dell Inspiron 15 3568 Display Assembly Replacement, Routing the Antenna Cables: étape 9, image 1 de 1
    • Route the antenna cables through its routing guides and slide the antenna cables through the slot on the computer base.
    • Close the display and turn the computer over.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 555 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 12
Total : 625
