Aller au contenu principal
Dell Inspiron 15 5565 Display Assembly Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15 5565 Display Assembly Replacement, Remove the Battery Cable: étape 1, image 1 de 1
  2. Dell Inspiron 15 5565 Display Assembly Replacement, Remove the Display Cable: étape 2, image 1 de 1
    • Note the display cable routing and remove the cable from its routing guides.
  3. Dell Inspiron 15 5565 Display Assembly Replacement, Disconnect the Display Cable: étape 3, image 1 de 2 Dell Inspiron 15 5565 Display Assembly Replacement, Disconnect the Display Cable: étape 3, image 2 de 2
    • Lift the latch and disconnect the display cable from the system board.
  4. Dell Inspiron 15 5565 Display Assembly Replacement, Remove the Screws: étape 4, image 1 de 1
    • Remove the screws that secure the display hinges to the palm rest and keyboard assembly.
  5. Dell Inspiron 15 5565 Display Assembly Replacement, Open the Display Hinges: étape 5, image 1 de 1
    • Open the display hinges.
  6. Dell Inspiron 15 5565 Display Assembly Replacement, Lifting the Assembly: étape 6, image 1 de 1
    • Lift the palm rest and keyboard assembly off the display assembly.
  7. Dell Inspiron 15 5565 Display Assembly Replacement, Placing the Palm Rest: étape 7, image 1 de 1
    • Place the palm rest and keyboard assembly on the NEW display assembly.
  8. Dell Inspiron 15 5565 Display Assembly Replacement, Press the Hinges Down: étape 8, image 1 de 1
    • Using the alignment posts, press the display hinges down on the palm rest and keyboard assembly.
  9. Dell Inspiron 15 5565 Display Assembly Replacement, Replace the Screws: étape 9, image 1 de 1
    • Replace the screws that secure the display hinges to the palm rest and keyboard assembly.
  10. Dell Inspiron 15 5565 Display Assembly Replacement, Routing the Display Cable: étape 10, image 1 de 1
    • Route the display cable through the routing guides on the palm rest and keyboard.
  11. Dell Inspiron 15 5565 Display Assembly Replacement, Sliding the Display Cable: étape 11, image 1 de 2 Dell Inspiron 15 5565 Display Assembly Replacement, Sliding the Display Cable: étape 11, image 2 de 2
    • Slide the display cable to the connector on the system board and close the latch to secure the cable.
    • Slide the battery cable to the connector on the system board.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 522 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 19
Total : 640
