Aller au contenu principal
Dell Inspiron 15 5565 Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15 5565 Hard Drive Replacement, Lifting the Latch: étape 1, image 1 de 3 Dell Inspiron 15 5565 Hard Drive Replacement, Lifting the Latch: étape 1, image 2 de 3 Dell Inspiron 15 5565 Hard Drive Replacement, Lifting the Latch: étape 1, image 3 de 3
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Lift the latch and using the pull tab, disconnect the hard-drive cable from the system board.
  2. Dell Inspiron 15 5565 Hard Drive Replacement, Remove the Screws: étape 2, image 1 de 1
    • Remove the screws that secure the hard-drive assembly to the palm rest and keyboard assembly.
  3. Dell Inspiron 15 5565 Hard Drive Replacement, Lifting the Hard Drive Assembly: étape 3, image 1 de 1
    • Lift the hard-drive assembly along with its cable off the palm rest and keyboard assembly.
  4. Dell Inspiron 15 5565 Hard Drive Replacement, Disconnecting the Interposer: étape 4, image 1 de 2 Dell Inspiron 15 5565 Hard Drive Replacement, Disconnecting the Interposer: étape 4, image 2 de 2
    • Disconnect the interposer from the hard-drive assembly.
  5. Dell Inspiron 15 5565 Hard Drive Replacement, Remove the Screws: étape 5, image 1 de 1
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  6. Dell Inspiron 15 5565 Hard Drive Replacement, Lifting the Hard Drive: étape 6, image 1 de 2 Dell Inspiron 15 5565 Hard Drive Replacement, Lifting the Hard Drive: étape 6, image 2 de 2
    • Lift the hard drive off the hard-drive bracket.
  7. Dell Inspiron 15 5565 Hard Drive Replacement, Align the Screw Holes: étape 7, image 1 de 1
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
  8. Dell Inspiron 15 5565 Hard Drive Replacement, Replace the Screws: étape 8, image 1 de 1
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  9. Dell Inspiron 15 5565 Hard Drive Replacement, Connecting the Interposer: étape 9, image 1 de 1
    • Connect the interposer to the hard-drive assembly.
  10. Dell Inspiron 15 5565 Hard Drive Replacement, Align the Screw Holes: étape 10, image 1 de 1
    • Align the screw holes on the hard-drive assembly with the screw holes on the palm rest and keyboard assembly.
  11. Dell Inspiron 15 5565 Hard Drive Replacement, Replace the Screws: étape 11, image 1 de 1
    • Replace the screws that secure the hard-drive assembly to the palm rest and keyboard assembly.
  12. Dell Inspiron 15 5565 Hard Drive Replacement, Connect the Hard Drive Cable: étape 12, image 1 de 1
    • Connect the hard-drive cable to the system board and close the latch to secure the cable.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 522 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 20
Total : 1,877
