Aller au contenu principal
Dell Inspiron 15 5565 IO Board Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15 5565 IO Board Replacement, Optical Drive: étape 1, image 1 de 1
    • Remove the 4 mm screw that secures the optical drive bracket to the optical drive using a Phillips #00 screwdriver.
  2. Dell Inspiron 15 5565 IO Board Replacement: étape 2, image 1 de 3 Dell Inspiron 15 5565 IO Board Replacement: étape 2, image 2 de 3 Dell Inspiron 15 5565 IO Board Replacement: étape 2, image 3 de 3
    • Eject the optical drive by pressing the eject button.
    • Push out the optical drive bracket using the iFixit opening tool.
  3. Dell Inspiron 15 5565 IO Board Replacement, Back Cover: étape 3, image 1 de 2 Dell Inspiron 15 5565 IO Board Replacement, Back Cover: étape 3, image 2 de 2
    • Remove 13 8 mm screws from the bottom of the device using a Phillips #00 screwdriver.
    • Remove the single 4 mm screw from the bottom of the device using a Phillips #00 screwdriver.
    • Remove the three 4 mm screws from the optical drive slot using a Phillips #00 screwdriver.
  4. Dell Inspiron 15 5565 IO Board Replacement: étape 4, image 1 de 2 Dell Inspiron 15 5565 IO Board Replacement: étape 4, image 2 de 2
    • Remove the back cover from the laptop.
  5. Dell Inspiron 15 5565 IO Board Replacement, IO Board: étape 5, image 1 de 3 Dell Inspiron 15 5565 IO Board Replacement, IO Board: étape 5, image 2 de 3 Dell Inspiron 15 5565 IO Board Replacement, IO Board: étape 5, image 3 de 3
    • Lift up the cover to pull out the cable.
  6. Dell Inspiron 15 5565 IO Board Replacement: étape 6, image 1 de 3 Dell Inspiron 15 5565 IO Board Replacement: étape 6, image 2 de 3 Dell Inspiron 15 5565 IO Board Replacement: étape 6, image 3 de 3
    • Remove the single 5 mm screw from the main part of the IO board using a Phillips #00 screwdriver.
    • Remove the IO board from the device.
Chad Welsh
Membre depuis le 03/10/23
85 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 6
Total : 131
