Aller au contenu principal
Dell Inspiron 15 5566 Memory Modules Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15 5566 Memory Modules Replacement, Lifting the Latch: étape 1, image 1 de 3 Dell Inspiron 15 5566 Memory Modules Replacement, Lifting the Latch: étape 1, image 2 de 3 Dell Inspiron 15 5566 Memory Modules Replacement, Lifting the Latch: étape 1, image 3 de 3
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Lift the latch and using the pull tab disconnect the hard-drive cable from the system board.
  2. Dell Inspiron 15 5566 Memory Modules Replacement, Remove the Screws: étape 2, image 1 de 1
    • Remove the four screws (M2.5x8) that secure the hard-drive assembly to the computer base.
  3. Dell Inspiron 15 5566 Memory Modules Replacement, Lifting the Hard Drive Assembly: étape 3, image 1 de 1
    • Lift the hard-drive assembly out of the computer base using the hard-drive pull tab.
  4. Dell Inspiron 15 5566 Memory Modules Replacement, Disconnecting the Interposer: étape 4, image 1 de 1
    • Disconnect the interposer from the hard drive.
  5. Dell Inspiron 15 5566 Memory Modules Replacement, Remove the Screws: étape 5, image 1 de 1
    • Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  6. Dell Inspiron 15 5566 Memory Modules Replacement, Lifting the Hard Drive Bracket: étape 6, image 1 de 2 Dell Inspiron 15 5566 Memory Modules Replacement, Lifting the Hard Drive Bracket: étape 6, image 2 de 2
    • Lift the hard-drive bracket out of the hard drive.
  7. Dell Inspiron 15 5566 Memory Modules Replacement, Placing the Hard Drive Bracket: étape 7, image 1 de 1
    • Place the hard-drive bracket on the NEW hard drive.
  8. Dell Inspiron 15 5566 Memory Modules Replacement, Align the Screw Holes: étape 8, image 1 de 1
    • Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
  9. Dell Inspiron 15 5566 Memory Modules Replacement, Replace the Screws: étape 9, image 1 de 1
    • Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  10. Dell Inspiron 15 5566 Memory Modules Replacement, Connect the Interposer: étape 10, image 1 de 1
    • Connect the interposer to the hard drive.
  11. Dell Inspiron 15 5566 Memory Modules Replacement, Placing the Hard Drive Assembly: étape 11, image 1 de 1
    • Place the hard-drive assembly in the computer base and align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  12. Dell Inspiron 15 5566 Memory Modules Replacement, Replace the Screws: étape 12, image 1 de 1
    • Replace the four screws (M2.5x8) that secure the hard-drive assembly to the computer base.
  13. Dell Inspiron 15 5566 Memory Modules Replacement, Sliding the Hard Drive Cable: étape 13, image 1 de 1
    • Slide the hard-drive cable into the connector and press down on the latch to secure the cable to the system board.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 522 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 1,544
