Aller au contenu principal
Dell Inspiron 15 5576 Gaming Display Assembly Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Disconnecting the Display Cable: étape 2, image 1 de 1
    • Using the pull tab, disconnect the display cable from the system board.
  2. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Note the Display Cable: étape 3, image 1 de 1
    • Note the display-cable routing and remove the cable from the routing guides on the computer base.
  3. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Disconnecting the Antenna Cables: étape 4, image 1 de 1
    • Disconnect the antenna cables from the wireless card.
  4. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Note the Antenna Cable Routing: étape 5, image 1 de 1
    • Note the antenna-cable routing and remove the antenna cables from the routing guides on the computer base.
  5. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Sliding the Display Cable: étape 6, image 1 de 1
    • Slide the display cable and antenna cables through the slots on the computer base.
  6. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Remove the Screws: étape 7, image 1 de 1
    • Remove the four screws (M2x5) that secure the display assembly to the computer base.
  7. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Lifting the Display Assembly: étape 8, image 1 de 1
    • Lift the display assembly off the computer base.
  8. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Align the Screw Holes: étape 9, image 1 de 1
    • Align the screw holes on the NEW display assembly with the screw holes on the computer base.
  9. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Replace the Screws: étape 10, image 1 de 1
    • Replace the four screws (M2x5) that secure the display assembly to the computer base.
  10. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Sliding the Display Cable: étape 11, image 1 de 1
    • Slide the display cable and antenna cables through the slot on the computer base.
  11. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Route the Display Cable: étape 12, image 1 de 1
    • Close the display and turn the computer over.
    • Route the display cable and antenna cables through the routing guides on the computer base.
  12. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Connect the Antenna Cables: étape 13, image 1 de 1
    • Connect the antenna cables to the wireless card.
  13. Dell Inspiron 15 5576 Gaming Display Assembly Replacement, Connecting the Display Cable: étape 14, image 1 de 1
    • Connect the display cable to the system board.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 522 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 3
Total : 694
