Aller au contenu principal
Dell Inspiron 15 5577 Gaming Hard-Drive Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement, Hard-Drive: étape 1, image 1 de 1
    • Turn your Dell Inspiron laptop up side down to locate a screw at the top of the device.
    • Unscrew the back cover with your Phillips Head screwdriver.
  2. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: étape 2, image 1 de 1
    • Remove the back cover. If you're having difficulty removing it, use a plastic opening tool, and pry the back cover away from the laptop.
  3. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: étape 3, image 1 de 1
    • Unscrew all 4 screws located around the hard drive.
  4. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: étape 4, image 1 de 1
    • Remove the cable above the hard drive. This can be done with a gentle tug perpendicular to the surface it is attached to.
  5. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: étape 5, image 1 de 1
    • Remove the hard drive. If you're having difficulty removing it, use a plastic opening tool.
  6. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: étape 6, image 1 de 1
    • Unscrew the four screws on the hard drive casing.
  7. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: étape 7, image 1 de 1
    • Remove the hard drive casing. If you're having difficulty removing it, use a plastic opening tool.
[deleted]
Membre depuis le 10/31/19
346 Réputation
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 28
30 derniers jours : 30
Total : 809
