Aller au contenu principal
Dell Inspiron 15 5577 Gaming Touch Pad Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15 5577 Gaming Touch Pad Replacement, Touch Pad: étape 1, image 1 de 1
    • Flip the computer over so the bottom side is up, then unscrew the base cover.
  2. Dell Inspiron 15 5577 Gaming Touch Pad Replacement: étape 2, image 1 de 2 Dell Inspiron 15 5577 Gaming Touch Pad Replacement: étape 2, image 2 de 2
    • Flip the computer back over and open the lid before removing the shell.
  3. Dell Inspiron 15 5577 Gaming Touch Pad Replacement: étape 3, image 1 de 3 Dell Inspiron 15 5577 Gaming Touch Pad Replacement: étape 3, image 2 de 3 Dell Inspiron 15 5577 Gaming Touch Pad Replacement: étape 3, image 3 de 3
    • Once the shell is removed, flip it and begin to pop out the touch pad.
2 autres ont terminé cette réparation.
Julia Cabral
Membre depuis le 10/31/19
403 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G7, Barthe Fall 2019 Membre de l'équipe UMass Dartmouth, Team S2-G7, Barthe Fall 2019
UMASSD-BARTHE-F19S2G7
2 membres
2 tutoriels rédigés
2 commentaires
Does the touchpad not require a connection?
Senbi Stevens - Réponse
WARNING! If you use this method, you will positively break your Dell 5577 laptop. The pictures of the laptop that are shown above must be from a laptop that was already broken. The tiny plastic rivets of the palmrest have plastic welds with the c-shell of the laptop. Therefore, you can certainly pull those rivets out by applying force but you cannot reattach them unless you use some kind of glue after performing this procedure. I followed this process. Now I have to replace my laptop’s C-shell. I don’t know what is the right process but the right process has to be from the bottom, NOT by taking out the palmrest and the top parts.
There is one more problem. If you use this process, it will be quite a pain to reattach the wire to the new touchpad, There is only a very tiny piece of the wire sticking out, which will be hard to reattach unless you apply force and pull out the wire. This is what I did.
If you are OK with reattaching the stuff with glue, you can use this process.
Rob - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 10
7 derniers jours : 24
30 derniers jours : 41
Total : 2,135
