Aller au contenu principal
Dell Inspiron 15 7579 Motherboard Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15 7579 Motherboard Replacement, Back Panel: étape 1, image 1 de 1
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 Motherboard Replacement: étape 2, image 1 de 2 Dell Inspiron 15 7579 Motherboard Replacement: étape 2, image 2 de 2
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 Motherboard Replacement, Fan: étape 3, image 1 de 2 Dell Inspiron 15 7579 Motherboard Replacement, Fan: étape 3, image 2 de 2
    • Remove the two 7.9 mm screws from the fan with a Phillips #0 screwdriver.
  4. Dell Inspiron 15 7579 Motherboard Replacement: étape 4, image 1 de 2 Dell Inspiron 15 7579 Motherboard Replacement: étape 4, image 2 de 2
    • Unplug the wires from the port.
    • Be sure to pull from the plastic connector, not the wires.
  5. Dell Inspiron 15 7579 Motherboard Replacement: étape 5, image 1 de 1
    • Carefully lift the fan out of the computer.
  6. Dell Inspiron 15 7579 Motherboard Replacement, SSD M.2 Drive: étape 6, image 1 de 1
    • Remove the single 3.6 mm screw holding the left side of the M.2 SSD card with a Phillips PH0 screwdriver.
  7. Dell Inspiron 15 7579 Motherboard Replacement: étape 7, image 1 de 1
    • Gently pull out the SSD card at the angle it is relaxed in to remove it. It is easiest to do this by hand.
    • Be gentle when pulling the SSD card out. It should take little effort to get it to slide out properly.
  8. Dell Inspiron 15 7579 Motherboard Replacement, Motherboard: étape 8, image 1 de 2 Dell Inspiron 15 7579 Motherboard Replacement, Motherboard: étape 8, image 2 de 2
    • Remove the six 2.1 mm screws with the Phillips #0 screwdriver.
  9. Dell Inspiron 15 7579 Motherboard Replacement: étape 9, image 1 de 2 Dell Inspiron 15 7579 Motherboard Replacement: étape 9, image 2 de 2
    • Unplug the eight ribbon cables connected to the motherboard.
  10. Dell Inspiron 15 7579 Motherboard Replacement: étape 10, image 1 de 1
    • Lift the motherboard up from the side opposite of the external ports and remove it from the laptop.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 16
Total : 506
