Aller au contenu principal
Dell Inspiron 15 7579 RAM (Memory) Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15 7579 RAM (Memory) Replacement, Back Panel: étape 1, image 1 de 1
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 RAM (Memory) Replacement: étape 2, image 1 de 2 Dell Inspiron 15 7579 RAM (Memory) Replacement: étape 2, image 2 de 2
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 RAM (Memory) Replacement, RAM (Memory): étape 3, image 1 de 1
    • Fold protective flaps to the side on the RAM module located in the upper right corner of the laptop.
  4. Dell Inspiron 15 7579 RAM (Memory) Replacement: étape 4, image 1 de 3 Dell Inspiron 15 7579 RAM (Memory) Replacement: étape 4, image 2 de 3 Dell Inspiron 15 7579 RAM (Memory) Replacement: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Use the tweezers to push the crimping metal away from the chip. The chip will pop up into an angled position.
    • Remove the chip by pulling at the same angle as the chip with the tweezers.
  5. Dell Inspiron 15 7579 RAM (Memory) Replacement: étape 5, image 1 de 3 Dell Inspiron 15 7579 RAM (Memory) Replacement: étape 5, image 2 de 3 Dell Inspiron 15 7579 RAM (Memory) Replacement: étape 5, image 3 de 3
    • Fold the plastic flap over on the other side.
    • As before, pull the fasteners away from the chip with the tweezers.
    • Remove the chip by carefully pulling it out with the tweezers.
  6. Dell Inspiron 15 7579 RAM (Memory) Replacement: étape 6, image 1 de 2 Dell Inspiron 15 7579 RAM (Memory) Replacement: étape 6, image 2 de 2
    • When reassembling, you must match the notch in the card with the notch in the connector header shown in red.
    • Doing otherwise will break the stick if forced.
Inaki Madrigal
Membre depuis le 04/23/18
760 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team S24-G9, Maness Spring 2018 Membre de l'équipe Cal Poly, Team S24-G9, Maness Spring 2018
CPSU-MANESS-S18S24G9
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 12
Total : 690
