Aller au contenu principal
Dell Inspiron 15 Optical Drive Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15 Optical Drive Replacement, Battery: étape 1, image 1 de 2 Dell Inspiron 15 Optical Drive Replacement, Battery: étape 1, image 2 de 2
    • Make sure your laptop is powered off completely and is not connected to the charger.
    • Close the laptop and place it so that the back of the screen is lying flat on your work surface.
    • Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
  2. Dell Inspiron 15 Optical Drive Replacement: étape 2, image 1 de 1
    • Lift the battery at an angle using your fingertips and remove it from the laptop.
    • Press and hold the power button for 5 seconds. This ensures that any remaining power will drain out of the computer.
  3. Dell Inspiron 15 Optical Drive Replacement, Optical Drive: étape 3, image 1 de 2 Dell Inspiron 15 Optical Drive Replacement, Optical Drive: étape 3, image 2 de 2
    • Remove the 5mm long Phillips #0 screw that is holding the optical drive in place, as pictured.
    • You can now slide the optical disk drive out of the computer.
    • You do not have to remove the base cover or the Hard Drive if you want to remove just the optical drive.
3 autres ont terminé cette réparation.
Edward Pacheco
Membre depuis le 03/06/16
833 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 5-8, Landers Spring 2016 Membre de l'équipe UMass Dartmouth, Team 5-8, Landers Spring 2016
UMASSD-LANDERS-S16S5G8
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 32
Total : 4,727
