Introduction
You will be able to remove and replace the Ram in your computer with ease after this guide.
Ce dont vous avez besoin
Close the laptop and place it so that the back of the screen is lying flat on your work surface.
Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
Remove the bottom cover by removing the 4 mm screw using a PH-0 Phillips screwdriver that secures the base cover to the laptop base.
Using the plastic opening tool, pry the base cover from the base.
Slide the base cover towards you and remove it from the base. Put it aside.
4 autres ont terminé cette réparation.
