Aller au contenu principal
Dell Inspiron 15-3521 RAM Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15-3521 RAM Replacement, Remove the battery: étape 1, image 1 de 3 Dell Inspiron 15-3521 RAM Replacement, Remove the battery: étape 1, image 2 de 3 Dell Inspiron 15-3521 RAM Replacement, Remove the battery: étape 1, image 3 de 3
    • We are removing the battery to avoid the possibility of an electrical discharge when working with this system.
    • Flip the laptop over.
    • Slide the latches toward the outside of the laptop to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3521 RAM Replacement, Remove access door: étape 2, image 1 de 3 Dell Inspiron 15-3521 RAM Replacement, Remove access door: étape 2, image 2 de 3 Dell Inspiron 15-3521 RAM Replacement, Remove access door: étape 2, image 3 de 3
    • Loosen the two screws attaching the access door to the laptop body
    • Using a spudger, pry open the access door from the laptop
    • Using your fingers, open and remove the access door from the laptop, exposing the memory cards underneath.
  3. Dell Inspiron 15-3521 RAM Replacement, Memory Card Removal/Replacement: étape 3, image 1 de 3 Dell Inspiron 15-3521 RAM Replacement, Memory Card Removal/Replacement: étape 3, image 2 de 3 Dell Inspiron 15-3521 RAM Replacement, Memory Card Removal/Replacement: étape 3, image 3 de 3
    • To access the memory cards, push out the latches on the left and right of the memory cards
    • To remove the memory card, pull it out of the tray with the latches still stretched out
    • Insert a new memory card in to the memory card tray, depressing until side latches engage with a click.
7 autres ont terminé cette réparation.
Andrew Dippre
Membre depuis le 10/13/14
2 902 Réputation
7 tutoriels rédigés
Équipe
Clemson, Team 3-1, Benson Fall 2014 Membre de l'équipe Clemson, Team 3-1, Benson Fall 2014
CLEM-BENSON-F14S3G1
4 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 13
30 derniers jours : 19
Total : 6,432
