Aller au contenu principal
Dell Inspiron 15-3521 Wireless Card Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15-3521 Wireless Card Replacement, Remove the Battery: étape 1, image 1 de 3 Dell Inspiron 15-3521 Wireless Card Replacement, Remove the Battery: étape 1, image 2 de 3 Dell Inspiron 15-3521 Wireless Card Replacement, Remove the Battery: étape 1, image 3 de 3
    • Flip the laptop over.
    • Slide the latches toward the outside of the laptop to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3521 Wireless Card Replacement, Removing Keyboard: étape 2, image 1 de 3 Dell Inspiron 15-3521 Wireless Card Replacement, Removing Keyboard: étape 2, image 2 de 3 Dell Inspiron 15-3521 Wireless Card Replacement, Removing Keyboard: étape 2, image 3 de 3
    • Flip laptop right side up
    • Using a flat head screwdriver, depress locking tabs holding keyboard into place
    • Using a spudger, pry the keyboard from the laptop, giving room to access with hands.
    • Using hands, remove keyboard completely from laptop body, leaving only the connecting cord that attaches the keyboard to the laptop.
  3. Dell Inspiron 15-3521 Wireless Card Replacement, Disconnecting the Keyboard Cable: étape 3, image 1 de 3 Dell Inspiron 15-3521 Wireless Card Replacement, Disconnecting the Keyboard Cable: étape 3, image 2 de 3 Dell Inspiron 15-3521 Wireless Card Replacement, Disconnecting the Keyboard Cable: étape 3, image 3 de 3
    • To disconnect the keyboard, locate the keyboard cable locking mechanism.
    • Open the locking mechanism by gently pulling up.
    • Slide out the keyboard cable from the interface to separate the keyboard form the laptop.
  4. Dell Inspiron 15-3521 Wireless Card Replacement, Wireless Card Removal: étape 4, image 1 de 3 Dell Inspiron 15-3521 Wireless Card Replacement, Wireless Card Removal: étape 4, image 2 de 3 Dell Inspiron 15-3521 Wireless Card Replacement, Wireless Card Removal: étape 4, image 3 de 3
    • Remove the wireless card cables powering the wireless card
    • Unscrew the wireless card using a PH0 screwdriver.
    • Replace with a new wireless card, reattaching the power cables.
7 autres ont terminé cette réparation.
Andrew Dippre
Membre depuis le 10/13/14
2 902 Réputation
7 tutoriels rédigés
Équipe
Clemson, Team 3-1, Benson Fall 2014 Membre de l'équipe Clemson, Team 3-1, Benson Fall 2014
CLEM-BENSON-F14S3G1
4 membres
9 tutoriels rédigés
2 commentaires
On an Insperion 15 model 3878, the Wi-Fi adapter wasn't under the keyboard. It was under the inset cover on the bottom.
I reseated the card connection and then Windows could communicate to configure it.
Student4Life - Réponse
its wlan is right now 2.4ghz. i want to upgrade it to 5ghz. please suggest a solution!
rohit nair - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 13
30 derniers jours : 23
Total : 6,162
