Aller au contenu principal
Dell Inspiron 15-3542 LCD Screen Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15-3542 LCD Screen Replacement, LCD Screen: étape 1, image 1 de 3 Dell Inspiron 15-3542 LCD Screen Replacement, LCD Screen: étape 1, image 2 de 3 Dell Inspiron 15-3542 LCD Screen Replacement, LCD Screen: étape 1, image 3 de 3
    • Power off the laptop.
    • Flip the laptop over so the bottom is facing up.
    • Slide the right button to the unlock symbol.
    • Slide the left button to the other unlock symbol.
    • While holding the left button, use your right finger to raise the battery up from the laptop.
  2. Dell Inspiron 15-3542 LCD Screen Replacement: étape 2, image 1 de 3 Dell Inspiron 15-3542 LCD Screen Replacement: étape 2, image 2 de 3 Dell Inspiron 15-3542 LCD Screen Replacement: étape 2, image 3 de 3
    • Flip the laptop over so the top is facing up and open the laptop.
    • Using both hands, unsnap the tabs around the perimeter of the bezel and remove it from the laptop.
  3. Dell Inspiron 15-3542 LCD Screen Replacement: étape 3, image 1 de 3 Dell Inspiron 15-3542 LCD Screen Replacement: étape 3, image 2 de 3 Dell Inspiron 15-3542 LCD Screen Replacement: étape 3, image 3 de 3
    • Remove the four screws from the corners of the LCD using a Phillips screwdriver.
    • Lift the screen up and place it on the keyboard.
  4. Dell Inspiron 15-3542 LCD Screen Replacement: étape 4, image 1 de 3 Dell Inspiron 15-3542 LCD Screen Replacement: étape 4, image 2 de 3 Dell Inspiron 15-3542 LCD Screen Replacement: étape 4, image 3 de 3
    • Gently peel off the yellow clear tape securing the video connector.
    • Use an opening tool to flip open the video connector bracket.
    • Make sure not to force the video cable when removing it from the connector bracket.
    • Disconnect the cable from the LCD screen and remove the LCD from the laptop.
Najeemdeen Lamidi
Membre depuis le 09/19/20
130 Réputation
1 tutoriel rédigé
Équipe
York University, Team S3-G48, Melo-Thaiss Fall 2020 Membre de l'équipe York University, Team S3-G48, Melo-Thaiss Fall 2020
YORK-MELO-THAISS-F20S3G48
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 9
Total : 1,177
