Aller au contenu principal
Dell Inspiron 15-3543 Keyboard Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15-3543 Keyboard Replacement, Keyboard: étape 1, image 1 de 2 Dell Inspiron 15-3543 Keyboard Replacement, Keyboard: étape 1, image 2 de 2
    • Turn the device over and open it.
    • You will see 5 notches at the top of the keyboard.
    • Stick the end of the metal spudger between each of these notches to pry the keyboard up. Once you hear a pop sound, stop and move onto the next notch.
  2. Dell Inspiron 15-3543 Keyboard Replacement: étape 2, image 1 de 2 Dell Inspiron 15-3543 Keyboard Replacement: étape 2, image 2 de 2
    • Once all five notches at the top of the keyboard are loosened, begin pulling it up from the top.
    • Pull the keyboard up slowly so you don't tear the ribbon cable out or damage it.
  3. Dell Inspiron 15-3543 Keyboard Replacement: étape 3, image 1 de 2 Dell Inspiron 15-3543 Keyboard Replacement: étape 3, image 2 de 2
    • To remove the ribbon cable, use the metal spudger tool to pop the ribbon cable lock up.
    • After popping up the ribbon cable lock, you can pull the ribbon cable out.
2 autres ont terminé cette réparation.
Brianna Blackburn
Membre depuis le 01/23/18
954 Réputation
4 tutoriels rédigés
Un commentaire
Thanks. Could you please suggest a recommended replacement keyboard? I didn't find any branded replacement item in Amazon.
Arun Prasad - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 21
30 derniers jours : 32
Total : 1,192
