Aller au contenu principal
Dell Inspiron 15-5547 Battery Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15-5547 Battery Replacement, Battery: étape 1, image 1 de 3 Dell Inspiron 15-5547 Battery Replacement, Battery: étape 1, image 2 de 3 Dell Inspiron 15-5547 Battery Replacement, Battery: étape 1, image 3 de 3
    • Flip the laptop on it's top and lay to a rest position.
    • Using the Phillips J0 screwdriver, remove the two indicated screws.
  2. Dell Inspiron 15-5547 Battery Replacement: étape 2, image 1 de 1
    • Use the spudger to carefully remove the back cover to get into the internals. Stick the spudger into the slot indicated in the photo by the marker.
    • Pry up from the slot, then pry up around the sides of the panel. The panel can then be removed by lifting the side with the slot and puling in that direction.
  3. Dell Inspiron 15-5547 Battery Replacement: étape 3, image 1 de 1
    • Use a Phillips J0 screwdriver in order to remove the screws indicated by the markers in the picture. It will be a total of 5 screws. Careful not to puncture the battery.
    • Carefully remove the battery by puling on the black tab.
3 autres ont terminé cette réparation.
Javier Solis
Membre depuis le 09/25/17
315 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 13
30 derniers jours : 16
Total : 2,251
