Aller au contenu principal
Dell Inspiron 15-5548 Battery Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15-5548 Battery Replacement, Battery: étape 1, image 1 de 3 Dell Inspiron 15-5548 Battery Replacement, Battery: étape 1, image 2 de 3 Dell Inspiron 15-5548 Battery Replacement, Battery: étape 1, image 3 de 3
    • Make sure the computer is unplugged and turned off before you start this procedure.
    • Look on the bottom of the computer. Locate the 2 screws. (Picture 1)
    • Using the Phillips 00 Screwdriver, unscrew both screws, and remove the bottom cover. The bottom cover can be hard to pull off, so you may need to pry it off with a pry tool.
  2. Dell Inspiron 15-5548 Battery Replacement: étape 2, image 1 de 2 Dell Inspiron 15-5548 Battery Replacement: étape 2, image 2 de 2
    • Locate the large black battery.
    • Locate the 4 screws on the battery, and remove them using the Philips 00 Screwdriver.
  3. Dell Inspiron 15-5548 Battery Replacement: étape 3, image 1 de 2 Dell Inspiron 15-5548 Battery Replacement: étape 3, image 2 de 2
    • Pull up on the release tab.
    • Remove the battery.
To reassemble your device and add in a new battery, follow these instructions in reverse order.
2 autres ont terminé cette réparation.
Hunter Oliver
Membre depuis le 09/20/17
288 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 24
30 derniers jours : 50
Total : 4,192
