Aller au contenu principal
Dell Inspiron 15-5552 Memory Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15-5552 Memory Replacement, Battery: étape 1, image 1 de 1
    • Make sure the laptop is powered down before you remove the battery.
  2. Dell Inspiron 15-5552 Memory Replacement: étape 2, image 1 de 1
    • Locate the battery release switch on the bottom of the laptop.
  3. Dell Inspiron 15-5552 Memory Replacement: étape 3, image 1 de 1
    • Slide the battery release switch away from the lock symbol towards the “unlock” position.
    • You can tell that the battery is unlocked once you hear a "click."
  4. Dell Inspiron 15-5552 Memory Replacement: étape 4, image 1 de 2 Dell Inspiron 15-5552 Memory Replacement: étape 4, image 2 de 2
    • Rotate the battery outward by lifting the bottom lip that pops out.
    • Continue rotating the battery towards the top of the laptop until the battery is completely removed.
  5. Dell Inspiron 15-5552 Memory Replacement, Screw Location: étape 5, image 1 de 1
    • Flip the device on its back, locate the screws circled.
  6. Dell Inspiron 15-5552 Memory Replacement, Screw Removal: étape 6, image 1 de 1
    • Use a J0 screwdriver to unscrew the two, 6mm Phillips screw on the rear-cover.
  7. Dell Inspiron 15-5552 Memory Replacement, Removing Cover: étape 7, image 1 de 3 Dell Inspiron 15-5552 Memory Replacement, Removing Cover: étape 7, image 2 de 3 Dell Inspiron 15-5552 Memory Replacement, Removing Cover: étape 7, image 3 de 3
    • Using a spudger, Lightly lift the rear-cover up and at an angle, away from the computer.
  8. Dell Inspiron 15-5552 Memory Replacement, RAM Removal: étape 8, image 1 de 2 Dell Inspiron 15-5552 Memory Replacement, RAM Removal: étape 8, image 2 de 2
    • Use your fingers to carefully pull the securing clips on the RAM away from each other.
    • The RAM should pop up when the clips are released.
  9. Dell Inspiron 15-5552 Memory Replacement, RAM Removal Contiuned: étape 9, image 1 de 2 Dell Inspiron 15-5552 Memory Replacement, RAM Removal Contiuned: étape 9, image 2 de 2
    • Remove the dislodged up RAM by pulling it away from the connection.
    • If it does not pop up, pry it out in a steady and straight direction.
Chandler Champion
Membre depuis le 01/23/18
364 Réputation
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 298
