Aller au contenu principal
Dell Inspiron 15-5558 Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15-5558 Hard Drive Replacement, Battery: étape 1, image 1 de 1
    • Make sure you turn off the device before starting.
    • Flip the device over and so the white bar code is on the right.
  2. Dell Inspiron 15-5558 Hard Drive Replacement: étape 2, image 1 de 1
    • Slide the battery latch all the way to the left until you hear the click and see the battery prop up.
  3. Dell Inspiron 15-5558 Hard Drive Replacement: étape 3, image 1 de 2 Dell Inspiron 15-5558 Hard Drive Replacement: étape 3, image 2 de 2
    • Rotate the battery up and remove it.
  4. Dell Inspiron 15-5558 Hard Drive Replacement, Hard Drive: étape 4, image 1 de 3 Dell Inspiron 15-5558 Hard Drive Replacement, Hard Drive: étape 4, image 2 de 3 Dell Inspiron 15-5558 Hard Drive Replacement, Hard Drive: étape 4, image 3 de 3
    • Using a Phillips #0 screwdriver, unscrew the two 8mm screws from the panel.
    • Take a spudger and wedge it between the panel and the base of the device.
    • Push down on the spudger until you hear a click sound.
    • Slide the spudger along the panel and continue to push down until the panel is completely detached.
    • Remove the panel.
  5. Dell Inspiron 15-5558 Hard Drive Replacement: étape 5, image 1 de 3 Dell Inspiron 15-5558 Hard Drive Replacement: étape 5, image 2 de 3 Dell Inspiron 15-5558 Hard Drive Replacement: étape 5, image 3 de 3
    • Using the Phillips #0 screwdriver, remove the four 8mm screws holding down the hard drive.
    • Take the spudger and prop up the connector so it is no longer attached.
    • Use the spudger and prop up the hard drive and remove it.
4 autres ont terminé cette réparation.
Adam Lourenco
Membre depuis le 10/19/17
793 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G4, Bailey Fall 2017 Membre de l'équipe UMass Dartmouth, Team S3-G4, Bailey Fall 2017
UMASSD-BAILEY-F17S3G4
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 27
30 derniers jours : 38
Total : 4,923
