Aller au contenu principal
Dell Inspiron 15-5558 Keyboard Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15-5558 Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Make sure you turn off the device before starting.
    • Flip the device over and so the white bar code is on the right.
  2. Dell Inspiron 15-5558 Keyboard Replacement: étape 2, image 1 de 1
    • Slide the battery latch all the way to the left until you hear the click and see the battery prop up.
  3. Dell Inspiron 15-5558 Keyboard Replacement: étape 3, image 1 de 2 Dell Inspiron 15-5558 Keyboard Replacement: étape 3, image 2 de 2
    • Rotate the battery up and remove it.
  4. Dell Inspiron 15-5558 Keyboard Replacement, Keyboard: étape 4, image 1 de 3 Dell Inspiron 15-5558 Keyboard Replacement, Keyboard: étape 4, image 2 de 3 Dell Inspiron 15-5558 Keyboard Replacement, Keyboard: étape 4, image 3 de 3
    • Identify the two small slots along the side of the keyboard closest to the screen.
    • Wedge the spudger in the two small slots and push the spudger in and down to detach the pins.
    • Using your hands, pull the keyboard up and out.
  5. Dell Inspiron 15-5558 Keyboard Replacement: étape 5, image 1 de 3 Dell Inspiron 15-5558 Keyboard Replacement: étape 5, image 2 de 3 Dell Inspiron 15-5558 Keyboard Replacement: étape 5, image 3 de 3
    • At the end of the ribbon cable attaching the keyboard to the device is a bar secure.
    • Using your finger or spudger, flip the bar up and the keyboard will be freed from the device.
5 autres ont terminé cette réparation.
Adam Lourenco
Membre depuis le 10/19/17
793 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G4, Bailey Fall 2017 Membre de l'équipe UMass Dartmouth, Team S3-G4, Bailey Fall 2017
UMASSD-BAILEY-F17S3G4
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 12
30 derniers jours : 17
Total : 1,932
