Aller au contenu principal
Dell Inspiron 15-5559 Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15-5559 Hard Drive Replacement, Back Panel: étape 1, image 1 de 2 Dell Inspiron 15-5559 Hard Drive Replacement, Back Panel: étape 1, image 2 de 2
    • Use a Phillips #1 screwdriver to remove the two 2.5x8mm screws on the back panel.
  2. Dell Inspiron 15-5559 Hard Drive Replacement: étape 2, image 1 de 2 Dell Inspiron 15-5559 Hard Drive Replacement: étape 2, image 2 de 2
    • Place the plastic spudger in the slot. Using the flat side of the spudger pry the back panel upward and off.
    • Do not be afraid to use a bit of muscle, as the panel does not come off without some force.
  3. Dell Inspiron 15-5559 Hard Drive Replacement, Hard Drive: étape 3, image 1 de 3 Dell Inspiron 15-5559 Hard Drive Replacement, Hard Drive: étape 3, image 2 de 3 Dell Inspiron 15-5559 Hard Drive Replacement, Hard Drive: étape 3, image 3 de 3
    • Remove each of the four (4) 2.5x8mm screws that anchor the hard drive using a Phillips #1 screwdriver.
  4. Dell Inspiron 15-5559 Hard Drive Replacement: étape 4, image 1 de 1
    • Use the plastic spudger to remove the hard drive conductive tape by lifting the black clasp holding it down, then pulling the conductive tape toward the left to remove it.
    • It does not take much force to remove the conductive tape. Remove it gently so that you do not damage it.
  5. Dell Inspiron 15-5559 Hard Drive Replacement: étape 5, image 1 de 2 Dell Inspiron 15-5559 Hard Drive Replacement: étape 5, image 2 de 2
    • Place the plastic spudger underneath the hard drive at the indicated position.
    • Use the spudger along with your other hand to gently remove the hard drive.
4 autres ont terminé cette réparation.
Kyla Ward
Membre depuis le 03/19/18
649 Réputation
4 tutoriels rédigés
Équipe
Baylor, Team S5-G5, Williams Spring 2018 Membre de l'équipe Baylor, Team S5-G5, Williams Spring 2018
BU-WILLIAMS-S18S5G5
3 membres
5 tutoriels rédigés
2 commentaires
The blue part came off is that important?
walterandradeconde - Réponse
can i put this in a harddrive enclosure?
chiggly 123 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 15
30 derniers jours : 31
Total : 5,476
