Aller au contenu principal
Dell Inspiron 15-5565 Battery Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15-5565 Battery Replacement, Optical Drive: étape 1, image 1 de 1
    • Remove the 4 mm screw that secures the optical drive bracket to the optical drive using a Phillips #00 screwdriver.
  2. Dell Inspiron 15-5565 Battery Replacement: étape 2, image 1 de 3 Dell Inspiron 15-5565 Battery Replacement: étape 2, image 2 de 3 Dell Inspiron 15-5565 Battery Replacement: étape 2, image 3 de 3
    • Eject the optical drive by pressing the eject button.
    • Push out the optical drive bracket using the iFixit opening tool.
  3. Dell Inspiron 15-5565 Battery Replacement, Back Cover: étape 3, image 1 de 2 Dell Inspiron 15-5565 Battery Replacement, Back Cover: étape 3, image 2 de 2
    • Remove 13 8 mm screws from the bottom of the device using a Phillips #00 screwdriver.
    • Remove the single 4 mm screw from the bottom of the device using a Phillips #00 screwdriver.
    • Remove the three 4 mm screws from the optical drive slot using a Phillips #00 screwdriver.
  4. Dell Inspiron 15-5565 Battery Replacement: étape 4, image 1 de 2 Dell Inspiron 15-5565 Battery Replacement: étape 4, image 2 de 2
    • Remove the back cover from the laptop.
  5. Dell Inspiron 15-5565 Battery Replacement, Battery: étape 5, image 1 de 2 Dell Inspiron 15-5565 Battery Replacement, Battery: étape 5, image 2 de 2
    • Remove the three 5 mm screws from the battery bracket using a Phillips #00 screwdriver.
  6. Dell Inspiron 15-5565 Battery Replacement: étape 6, image 1 de 3 Dell Inspiron 15-5565 Battery Replacement: étape 6, image 2 de 3 Dell Inspiron 15-5565 Battery Replacement: étape 6, image 3 de 3
    • Remove the five 5 mm screws from the outer edges of the battery using a Phillips #00 screwdriver.
    • Remove the battery from the laptop.
Avery Wasylyszyn
Membre depuis le 03/08/23
228 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 6
30 derniers jours : 30
Total : 438
