Aller au contenu principal
Dell Inspiron 15-5565 RAM Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15-5565 RAM Replacement, Optical Drive: étape 1, image 1 de 1
    • Remove the 4 mm screw that secures the optical drive bracket to the optical drive using a Phillips #00 screwdriver.
  2. Dell Inspiron 15-5565 RAM Replacement: étape 2, image 1 de 3 Dell Inspiron 15-5565 RAM Replacement: étape 2, image 2 de 3 Dell Inspiron 15-5565 RAM Replacement: étape 2, image 3 de 3
    • Eject the optical drive by pressing the eject button.
    • Push out the optical drive bracket using the iFixit opening tool.
  3. Dell Inspiron 15-5565 RAM Replacement, Back Cover: étape 3, image 1 de 2 Dell Inspiron 15-5565 RAM Replacement, Back Cover: étape 3, image 2 de 2
    • Remove 13 8 mm screws from the bottom of the device using a Phillips #00 screwdriver.
    • Remove the single 4 mm screw from the bottom of the device using a Phillips #00 screwdriver.
    • Remove the three 4 mm screws from the optical drive slot using a Phillips #00 screwdriver.
  4. Dell Inspiron 15-5565 RAM Replacement: étape 4, image 1 de 2 Dell Inspiron 15-5565 RAM Replacement: étape 4, image 2 de 2
    • Remove the back cover from the laptop.
  5. Dell Inspiron 15-5565 RAM Replacement, RAM: étape 5, image 1 de 3 Dell Inspiron 15-5565 RAM Replacement, RAM: étape 5, image 2 de 3 Dell Inspiron 15-5565 RAM Replacement, RAM: étape 5, image 3 de 3
    • Use your fingers to pull the safety clips apart on either side of the memory module. This should make the module pop upwards.
    • Remove the module from its slot by pulling it out.
Caroline Bordelon
Membre depuis le 03/08/23
126 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 16
30 derniers jours : 19
Total : 188
