Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
In this guide, we will be showing you how to remove and replace the Display Assembly.
Pièces
Aucune pièce spécifiée.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer.  After working inside your computer, follow the instructions in After Working Inside Your Computer.
    Step one incorrectly identifies the display cable as the battery cable. I think I blew the mobo reattaching the display cable. A small pop and some ozone scent leads me to believe that.
    Quietech - Réponse
    Make your 1st step removing the back cover. Dell Inspiron 15-5567 Back Cover Replacement
    Quietech - Réponse
  2. Note the display cable routing and remove the cable from its routing guides.
    • Note the display cable routing and remove the cable from its routing guides.
  3. Lift the latch and disconnect the display cable from the system board. Lift the latch and disconnect the display cable from the system board.
    • Lift the latch and disconnect the display cable from the system board.
  4. Remove the screws that secure the display hinges to the palm rest and keyboard assembly.
    • Remove the screws that secure the display hinges to the palm rest and keyboard assembly.
  5. Open the display hinges.
    • Open the display hinges.
  6. Lift the palm rest and keyboard assembly off the display assembly.
    • Lift the palm rest and keyboard assembly off the display assembly.
  7. Place the palm rest and keyboard assembly on the NEW display assembly.
    • Place the palm rest and keyboard assembly on the NEW display assembly.
  8. Using the alignment posts, press the display hinges down on the palm rest and keyboard assembly.
    • Using the alignment posts, press the display hinges down on the palm rest and keyboard assembly.
  9. Replace the screws that secure the display hinges to the palm rest and keyboard assembly.
    • Replace the screws that secure the display hinges to the palm rest and keyboard assembly.
  10. Route the display cable through the routing guides on the palm rest and keyboard.
    • Route the display cable through the routing guides on the palm rest and keyboard.
  11. Slide the display cable to the connector on the system board and close the latch to secure the cable.
    • Slide the display cable to the connector on the system board and close the latch to secure the cable.
    • Slide the battery cable to the connector on the system board.
Ligne d'arrivée
Terrence15
Membre depuis le 18/12/2017
72 892 Réputation
442 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
32 membres
1 932 tutoriels rédigés
Nice, is the part available?
gideon onwuka - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 24
Total : 1,245
