Aller au contenu principal
Introduction
The CPU fan makes sure your CPU does not overheat. This guide shows the process of removing the CPU fan from the Dell Inspiron 15-7547.
Pièces
Aucune pièce spécifiée.
  1. Close the display and flip the laptop on its back.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Pry the cover open with a plastic spudger   and remove it.
    • Pry the cover open with a plastic spudger and remove it.
  3. Fix Kits pour batterie de MacBook
    À partir de $69.99
    Buy Now
    À partir de $69.99
    Buy Now
  4. Remove the two 5.0 mm-long Philips #0 screws from the fan. The screw marked in orange will remain captive to the fan.
    • Remove the two 5.0 mm-long Philips #0 screws from the fan.
    • The screw marked in orange will remain captive to the fan.
  5. Disconnect the wire that connects the fan to the motherboard. This can be found under the flap directly to the left of the fan. Disconnect the wire that connects the fan to the motherboard. This can be found under the flap directly to the left of the fan.
    • Disconnect the wire that connects the fan to the motherboard. This can be found under the flap directly to the left of the fan.
  6. Lift the fan out of the chassis.
    • Lift the fan out of the chassis.
Isaac Brooks
Membre depuis le 10/09/2018
331 Réputation
3 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 93
