Aller au contenu principal
Dell Inspiron 15-7547 Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15-7547 Hard Drive Replacement, Bottom Cover: étape 1, image 1 de 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 Hard Drive Replacement: étape 2, image 1 de 1
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Dell Inspiron 15-7547 Hard Drive Replacement, Hard Drive: étape 3, image 1 de 2 Dell Inspiron 15-7547 Hard Drive Replacement, Hard Drive: étape 3, image 2 de 2
    • Remove the four 5.0 mm-long Philips #0 screws connecting the hard drive to the chassis.
  4. Dell Inspiron 15-7547 Hard Drive Replacement: étape 4, image 1 de 2 Dell Inspiron 15-7547 Hard Drive Replacement: étape 4, image 2 de 2
    • Disconnect the hard drive from the motherboard by placing your fingers at the back, and pulling forward towards the front of the chassis.
  5. Dell Inspiron 15-7547 Hard Drive Replacement: étape 5, image 1 de 1
    • Lift the hard drive out of the chassis.
Isaac Brooks
Membre depuis le 09/10/18
355 Réputation
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 18
Total : 740
