Aller au contenu principal
Dell Inspiron 15-7547 LCD Assembly Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15-7547 LCD Assembly Replacement, Bottom Cover: étape 1, image 1 de 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 LCD Assembly Replacement: étape 2, image 1 de 1
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Dell Inspiron 15-7547 LCD Assembly Replacement, WiFi Card: étape 3, image 1 de 2 Dell Inspiron 15-7547 LCD Assembly Replacement, WiFi Card: étape 3, image 2 de 2
    • Remove the 3.0 mm-long Philips #0 screw at the end of the Wifi-Card
  4. Dell Inspiron 15-7547 LCD Assembly Replacement: étape 4, image 1 de 2 Dell Inspiron 15-7547 LCD Assembly Replacement: étape 4, image 2 de 2
    • Remove the Wifi-Card from its socket by pulling away and up from the connector.
  5. Dell Inspiron 15-7547 LCD Assembly Replacement: étape 5, image 1 de 2 Dell Inspiron 15-7547 LCD Assembly Replacement: étape 5, image 2 de 2
    • Disconnect the white and black cables from the Wifi-Card.
    • Make a note of which wire goes where for reconnecting them to the replacement card.
  6. Dell Inspiron 15-7547 LCD Assembly Replacement, LCD Assembly: étape 6, image 1 de 3 Dell Inspiron 15-7547 LCD Assembly Replacement, LCD Assembly: étape 6, image 2 de 3 Dell Inspiron 15-7547 LCD Assembly Replacement, LCD Assembly: étape 6, image 3 de 3
    • Remove the six 7.0 mm-long Philips #0 screws that mount the hinges.
  7. Dell Inspiron 15-7547 LCD Assembly Replacement: étape 7, image 1 de 3 Dell Inspiron 15-7547 LCD Assembly Replacement: étape 7, image 2 de 3 Dell Inspiron 15-7547 LCD Assembly Replacement: étape 7, image 3 de 3
    • Use a spudger to unlatch and unplug the display cable.
    • There will be a notch on the side of the connector.
  8. Dell Inspiron 15-7547 LCD Assembly Replacement: étape 8, image 1 de 3 Dell Inspiron 15-7547 LCD Assembly Replacement: étape 8, image 2 de 3 Dell Inspiron 15-7547 LCD Assembly Replacement: étape 8, image 3 de 3
    • Raise the left and right hinges.
  9. Dell Inspiron 15-7547 LCD Assembly Replacement: étape 9, image 1 de 1
    • Remove the LCD display assembly from the laptop.
Kevin Smith
Membre depuis le 09/10/18
321 Réputation
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 3
30 derniers jours : 29
Total : 832
