Aller au contenu principal
Dell Inspiron 15-7547 Motherboard Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15-7547 Motherboard Replacement, Bottom Cover: étape 1, image 1 de 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 Motherboard Replacement: étape 2, image 1 de 1
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Dell Inspiron 15-7547 Motherboard Replacement, Battery: étape 3, image 1 de 2 Dell Inspiron 15-7547 Motherboard Replacement, Battery: étape 3, image 2 de 2
    • Remove the five 5.0 mm-long Philips #0 screws that connect the battery to the case.
  4. Dell Inspiron 15-7547 Motherboard Replacement: étape 4, image 1 de 2 Dell Inspiron 15-7547 Motherboard Replacement: étape 4, image 2 de 2
    • Lift the battery out of the case.
  5. Dell Inspiron 15-7547 Motherboard Replacement: étape 5, image 1 de 3 Dell Inspiron 15-7547 Motherboard Replacement: étape 5, image 2 de 3 Dell Inspiron 15-7547 Motherboard Replacement: étape 5, image 3 de 3
    • Pull the battery cable's pull tab towards the battery to disconnect it from the motherboard.
    • Pull parallel to the motherboard, not straight up.
    • Most of the cable is attached to the case with adhesive, which may cause slight resistance.
    • Remove the battery.
  6. Dell Inspiron 15-7547 Motherboard Replacement, WiFi Card: étape 6, image 1 de 2 Dell Inspiron 15-7547 Motherboard Replacement, WiFi Card: étape 6, image 2 de 2
    • Remove the 3.0 mm-long Philips #0 screw at the end of the Wifi-Card
  7. Dell Inspiron 15-7547 Motherboard Replacement: étape 7, image 1 de 2 Dell Inspiron 15-7547 Motherboard Replacement: étape 7, image 2 de 2
    • Remove the Wifi-Card from its socket by pulling away and up from the connector.
  8. Dell Inspiron 15-7547 Motherboard Replacement: étape 8, image 1 de 2 Dell Inspiron 15-7547 Motherboard Replacement: étape 8, image 2 de 2
    • Disconnect the white and black cables from the Wifi-Card.
    • Make a note of which wire goes where for reconnecting them to the replacement card.
  9. Dell Inspiron 15-7547 Motherboard Replacement, Hard Drive: étape 9, image 1 de 2 Dell Inspiron 15-7547 Motherboard Replacement, Hard Drive: étape 9, image 2 de 2
    • Remove the four 5.0 mm-long Philips #0 screws connecting the hard drive to the chassis.
  10. Dell Inspiron 15-7547 Motherboard Replacement: étape 10, image 1 de 2 Dell Inspiron 15-7547 Motherboard Replacement: étape 10, image 2 de 2
    • Disconnect the hard drive from the motherboard by placing your fingers at the back, and pulling forward towards the front of the chassis.
  11. Dell Inspiron 15-7547 Motherboard Replacement: étape 11, image 1 de 1
    • Lift the hard drive out of the chassis.
  12. Dell Inspiron 15-7547 Motherboard Replacement, CPU Fan: étape 12, image 1 de 2 Dell Inspiron 15-7547 Motherboard Replacement, CPU Fan: étape 12, image 2 de 2
    • Remove the two 5.0 mm-long Philips #0 screws from the fan.
    • The screw marked in orange will remain captive to the fan.
  13. Dell Inspiron 15-7547 Motherboard Replacement: étape 13, image 1 de 2 Dell Inspiron 15-7547 Motherboard Replacement: étape 13, image 2 de 2
    • Disconnect the wire that connects the fan to the motherboard. This can be found under the flap directly to the left of the fan.
  14. Dell Inspiron 15-7547 Motherboard Replacement: étape 14, image 1 de 1
    • Lift the fan out of the chassis.
  15. Dell Inspiron 15-7547 Motherboard Replacement, RAM: étape 15, image 1 de 3 Dell Inspiron 15-7547 Motherboard Replacement, RAM: étape 15, image 2 de 3 Dell Inspiron 15-7547 Motherboard Replacement, RAM: étape 15, image 3 de 3
    • Remove the plastic heat spreader that covers the RAM sticks.
  16. Dell Inspiron 15-7547 Motherboard Replacement: étape 16, image 1 de 2 Dell Inspiron 15-7547 Motherboard Replacement: étape 16, image 2 de 2
    • Release the clamps on each side of the RAM sticks by pushing away from the center.
    • When done properly the RAM stick should pop up.
  17. Dell Inspiron 15-7547 Motherboard Replacement: étape 17, image 1 de 2 Dell Inspiron 15-7547 Motherboard Replacement: étape 17, image 2 de 2
    • Pull the RAM stick in a straight line out of the socket.
  18. Dell Inspiron 15-7547 Motherboard Replacement, LCD Assembly: étape 18, image 1 de 3 Dell Inspiron 15-7547 Motherboard Replacement, LCD Assembly: étape 18, image 2 de 3 Dell Inspiron 15-7547 Motherboard Replacement, LCD Assembly: étape 18, image 3 de 3
    • Remove the six 7.0 mm-long Philips #0 screws that mount the hinges.
  19. Dell Inspiron 15-7547 Motherboard Replacement: étape 19, image 1 de 3 Dell Inspiron 15-7547 Motherboard Replacement: étape 19, image 2 de 3 Dell Inspiron 15-7547 Motherboard Replacement: étape 19, image 3 de 3
    • Use a spudger to unlatch and unplug the display cable.
    • There will be a notch on the side of the connector.
  20. Dell Inspiron 15-7547 Motherboard Replacement: étape 20, image 1 de 3 Dell Inspiron 15-7547 Motherboard Replacement: étape 20, image 2 de 3 Dell Inspiron 15-7547 Motherboard Replacement: étape 20, image 3 de 3
    • Raise the left and right hinges.
  21. Dell Inspiron 15-7547 Motherboard Replacement: étape 21, image 1 de 1
    • Remove the LCD display assembly from the laptop.
  22. Dell Inspiron 15-7547 Motherboard Replacement, Motherboard: étape 22, image 1 de 3 Dell Inspiron 15-7547 Motherboard Replacement, Motherboard: étape 22, image 2 de 3 Dell Inspiron 15-7547 Motherboard Replacement, Motherboard: étape 22, image 3 de 3
    • Unlatch the ribbon cable by pulling the white release up.
    • If this proves to be difficult using your fingers, try a plastic spudger.
    • Hold the blue flap and pull to unplug the cable.
  23. Dell Inspiron 15-7547 Motherboard Replacement: étape 23, image 1 de 3 Dell Inspiron 15-7547 Motherboard Replacement: étape 23, image 2 de 3 Dell Inspiron 15-7547 Motherboard Replacement: étape 23, image 3 de 3
    • Unlatch black release on the ribbon cable.
    • Hold the blue flap to unplug the cable.
  24. Dell Inspiron 15-7547 Motherboard Replacement: étape 24, image 1 de 3 Dell Inspiron 15-7547 Motherboard Replacement: étape 24, image 2 de 3 Dell Inspiron 15-7547 Motherboard Replacement: étape 24, image 3 de 3
    • Unlatch the ribbon cable by pulling the black release up.
    • Unlike the others, this release is found at the back.
    • Hold the flap and unplug the cable.
  25. Dell Inspiron 15-7547 Motherboard Replacement: étape 25, image 1 de 3 Dell Inspiron 15-7547 Motherboard Replacement: étape 25, image 2 de 3 Dell Inspiron 15-7547 Motherboard Replacement: étape 25, image 3 de 3
    • Unlike the others this release is found at back.
    • Hold the blue flap and unplug the cable.
  26. Dell Inspiron 15-7547 Motherboard Replacement: étape 26, image 1 de 3 Dell Inspiron 15-7547 Motherboard Replacement: étape 26, image 2 de 3 Dell Inspiron 15-7547 Motherboard Replacement: étape 26, image 3 de 3
    • Unplug the DC jack cable.
  27. Dell Inspiron 15-7547 Motherboard Replacement: étape 27, image 1 de 2 Dell Inspiron 15-7547 Motherboard Replacement: étape 27, image 2 de 2
    • Remove the seven 3.0 mm-long Philips #0 screws that secure the motherboard.
  28. Dell Inspiron 15-7547 Motherboard Replacement: étape 28, image 1 de 1
    • Remove the motherboard from the laptop.
Kevin Smith
Membre depuis le 09/10/18
321 Réputation
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 17
30 derniers jours : 20
Total : 786
