Aller au contenu principal
Dell Inspiron 15-7547 RAM Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15-7547 RAM Replacement, Bottom Cover: étape 1, image 1 de 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 RAM Replacement: étape 2, image 1 de 1
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Dell Inspiron 15-7547 RAM Replacement, RAM: étape 3, image 1 de 3 Dell Inspiron 15-7547 RAM Replacement, RAM: étape 3, image 2 de 3 Dell Inspiron 15-7547 RAM Replacement, RAM: étape 3, image 3 de 3
    • Remove the plastic heat spreader that covers the RAM sticks.
  4. Dell Inspiron 15-7547 RAM Replacement: étape 4, image 1 de 2 Dell Inspiron 15-7547 RAM Replacement: étape 4, image 2 de 2
    • Release the clamps on each side of the RAM sticks by pushing away from the center.
    • When done properly the RAM stick should pop up.
  5. Dell Inspiron 15-7547 RAM Replacement: étape 5, image 1 de 2 Dell Inspiron 15-7547 RAM Replacement: étape 5, image 2 de 2
    • Pull the RAM stick in a straight line out of the socket.
Claro
Membre depuis le 09/10/18
591 Réputation
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 19
Total : 343
