Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
The guide shows the process of removing the WiFi card from your Dell Inspiron 15-7547 laptop.
Pièces
Aucune pièce spécifiée.
  1. Close the display and flip the laptop on its back.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Pry the cover open with a plastic spudger   and remove it.
    • Pry the cover open with a plastic spudger and remove it.
  3. Kits pour Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Remove the 3.0 mm-long Philips #0 screw at the end of the Wifi-Card Remove the 3.0 mm-long Philips #0 screw at the end of the Wifi-Card
    • Remove the 3.0 mm-long Philips #0 screw at the end of the Wifi-Card
  5. Remove the Wifi-Card from its socket by pulling away and up from the connector. Remove the Wifi-Card from its socket by pulling away and up from the connector.
    • Remove the Wifi-Card from its socket by pulling away and up from the connector.
  6. Disconnect the white and black cables from the Wifi-Card. Make a note of which wire goes where for reconnecting them to the replacement card.
    • Disconnect the white and black cables from the Wifi-Card.
    • Make a note of which wire goes where for reconnecting them to the replacement card.
Claro
Membre depuis le 10/09/2018
576 Réputation
5 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 85
