Aller au contenu principal
Dell Inspiron 15-7548 Motherboard Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15-7548 Motherboard Replacement, Back Panel: étape 1, image 1 de 2 Dell Inspiron 15-7548 Motherboard Replacement, Back Panel: étape 1, image 2 de 2
    • Remove the six 6 mm screws from the back panel with a Phillips #1 screwdriver.
    • Loosen the four captive screws at the bottom using a Phillips #1 screwdriver.
    • The four screws on the bottom are captive screws and cannot be removed.
  2. Dell Inspiron 15-7548 Motherboard Replacement: étape 2, image 1 de 2 Dell Inspiron 15-7548 Motherboard Replacement: étape 2, image 2 de 2
    • Pry out the back panel using the flat head side of the spudger.
    • Do not insert the spudger more than half an inch when separating the bottom and right side of the back panel.
  3. Dell Inspiron 15-7548 Motherboard Replacement, Motherboard: étape 3, image 1 de 1
    • Remove the screws holding the battery.
  4. Dell Inspiron 15-7548 Motherboard Replacement: étape 4, image 1 de 1
    • Disconnect the battery ribbon connector.
  5. Dell Inspiron 15-7548 Motherboard Replacement: étape 5, image 1 de 1
    • Disconnect the CPU fan ribbon.
  6. Dell Inspiron 15-7548 Motherboard Replacement: étape 6, image 1 de 1
    • Disconnect the display screen ribbon connector.
  7. Dell Inspiron 15-7548 Motherboard Replacement: étape 7, image 1 de 1
    • Disconnect the blue ribbon connector.
  8. Dell Inspiron 15-7548 Motherboard Replacement: étape 8, image 1 de 1
    • Disconnect the blue and gold ribbon connectors.
  9. Dell Inspiron 15-7548 Motherboard Replacement: étape 9, image 1 de 1
    • Disconnect the speaker cable.
  10. Dell Inspiron 15-7548 Motherboard Replacement: étape 10, image 1 de 1
    • Disconnect the WiFi card connections.
  11. Dell Inspiron 15-7548 Motherboard Replacement: étape 11, image 1 de 1
    • Remove the screws securing the heat sink.
  12. Dell Inspiron 15-7548 Motherboard Replacement: étape 12, image 1 de 1
    • Remove the heat sink.
  13. Dell Inspiron 15-7548 Motherboard Replacement: étape 13, image 1 de 1
    • Remove the motherboard screws.
  14. Dell Inspiron 15-7548 Motherboard Replacement: étape 14, image 1 de 1
    • Remove the motherboard.
Michael Nunez
Membre depuis le 04/12/22
325 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team 3-3, Beck Spring 2022 Membre de l'équipe IUPUI, Team 3-3, Beck Spring 2022
IUPUI-BECK-S22S3G3
4 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 11
Total : 700
