Aller au contenu principal
Dell Inspiron 15-7548 Speaker Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15-7548 Speaker Replacement, Back Panel: étape 1, image 1 de 2 Dell Inspiron 15-7548 Speaker Replacement, Back Panel: étape 1, image 2 de 2
    • Remove the six 6 mm screws from the back panel with a Phillips #1 screwdriver.
    • Loosen the four captive screws at the bottom using a Phillips #1 screwdriver.
    • The four screws on the bottom are captive screws and cannot be removed.
  2. Dell Inspiron 15-7548 Speaker Replacement: étape 2, image 1 de 2 Dell Inspiron 15-7548 Speaker Replacement: étape 2, image 2 de 2
    • Pry out the back panel using the flat head side of the spudger.
    • Do not insert the spudger more than half an inch when separating the bottom and right side of the back panel.
  3. Dell Inspiron 15-7548 Speaker Replacement, Battery: étape 3, image 1 de 2 Dell Inspiron 15-7548 Speaker Replacement, Battery: étape 3, image 2 de 2
    • Disconnect the battery from the motherboard by pulling the black tab attached to the cable.
  4. Dell Inspiron 15-7548 Speaker Replacement: étape 4, image 1 de 2 Dell Inspiron 15-7548 Speaker Replacement: étape 4, image 2 de 2
    • Remove the four 2.5x6mm screws using a Phillips #1 screwdriver.
  5. Dell Inspiron 15-7548 Speaker Replacement, Speaker: étape 5, image 1 de 1
    • Remove the ribbon cable by pulling it out.
  6. Dell Inspiron 15-7548 Speaker Replacement: étape 6, image 1 de 2 Dell Inspiron 15-7548 Speaker Replacement: étape 6, image 2 de 2
    • Remove the compression caps by using the spudger.
  7. Dell Inspiron 15-7548 Speaker Replacement: étape 7, image 1 de 1
    • Untangle the wire from the plastic clips and remove the speakers from the device.
3 autres ont terminé cette réparation.
brianna cordoway
Membre depuis le 09/26/18
151 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 15
30 derniers jours : 17
Total : 873
