Introduction
This guide will demonstrate how to replace the hard drive for the Dell Inspiron 15-7559. This may be necessary if your laptop frequently crashes or if you're having issues booting it.
Ce dont vous avez besoin
Turn off the computer.
Disconnect the charging cable from the computer.
Flip the computer upside down.
Use the blue, plastic opening tool to gently pry a section of the back panel open.
Next slide the opening tool around the back panel to disconnect the clips holding the panel in place.
After the clips have been disconnected, the back panel can then be easily lifted off the computer.
3 autres ont terminé cette réparation.
2 commentaires
Is there a step related to removing the hard drive mount? I believe that you’ll need the mount in order to screw a new drive into the system.
Are there other options beside the same seagate hard drive? I’m reading on forums that this hard drive is not very reliable. And since mine just completely died after less than 4 years I’m skeptable replacing it with the same exact hard drive?
