Aller au contenu principal
Dell Inspiron 15-7559 Keyboard Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15-7559 Keyboard Replacement, Keyboard: étape 1, image 1 de 3 Dell Inspiron 15-7559 Keyboard Replacement, Keyboard: étape 1, image 2 de 3 Dell Inspiron 15-7559 Keyboard Replacement, Keyboard: étape 1, image 3 de 3
    • Using the flat end of the spudger press in the 5 tabs, located on top of the keyboard, as you use the spudger to pry each section up.
    • After releasing the 5 tabs, slide the opening tool around the top and sides of the keyboard to make sure it is fully released.
  2. Dell Inspiron 15-7559 Keyboard Replacement: étape 2, image 1 de 2 Dell Inspiron 15-7559 Keyboard Replacement: étape 2, image 2 de 2
    • Now lift the keyboard enough to access the ribbon cables beneath it.
  3. Dell Inspiron 15-7559 Keyboard Replacement: étape 3, image 1 de 3 Dell Inspiron 15-7559 Keyboard Replacement: étape 3, image 2 de 3 Dell Inspiron 15-7559 Keyboard Replacement: étape 3, image 3 de 3
    • For the two ribbon cables connecting the keyboard to the laptop, use your finger to lift the latch up.
    • Once the latch is raised, lift the ribbon cable up and out of the latch.
  4. Dell Inspiron 15-7559 Keyboard Replacement: étape 4, image 1 de 1
    • Now that the keyboard has been fully disconnected from the laptop, lift it off of the device.
9 autres ont terminé cette réparation.
Trenton Greevebiester
Membre depuis le 10/19/17
1 587 Réputation
6 tutoriels rédigés
Équipe
UW Tacoma, Team S3-G2, Liner Fall 2017 Membre de l'équipe UW Tacoma, Team S3-G2, Liner Fall 2017
UWT-LINER-F17S3G2
5 membres
9 tutoriels rédigés
2 commentaires
How to put it back
Using Name - Réponse
Do the steps in reverse order, like it says at the end of the tutorial
Arthur Alford -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 19
30 derniers jours : 36
Total : 7,187
