Aller au contenu principal
Dell Inspiron 15-7567 RAM Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15-7567 RAM Replacement, Battery: étape 1, image 1 de 1
    • Turn off laptop before beginning.
    • Place the laptop upside down on a flat, stable surface.
  2. Dell Inspiron 15-7567 RAM Replacement: étape 2, image 1 de 2 Dell Inspiron 15-7567 RAM Replacement: étape 2, image 2 de 2
    • Remove the 3mm screw in the location shown, using a Phillips #1 screwdriver.
  3. Dell Inspiron 15-7567 RAM Replacement: étape 3, image 1 de 1
    • Remove the panel from the sides and pull it out at an angle towards you.
  4. Dell Inspiron 15-7567 RAM Replacement: étape 4, image 1 de 2 Dell Inspiron 15-7567 RAM Replacement: étape 4, image 2 de 2
    • Remove the five 3mm screws on the battery with a Torx (T8) screwdriver in the locations shown.
  5. Dell Inspiron 15-7567 RAM Replacement: étape 5, image 1 de 2 Dell Inspiron 15-7567 RAM Replacement: étape 5, image 2 de 2
    Outil utilisé dans cette étape :
    • Disconnect the power cord from the battery by using a pair of tweezers, your fingers, or the opening tools from the iFixit pro tech tool kit.
    • Pinch the clips on the left and right side while pulling on the cord at the same time.
  6. Dell Inspiron 15-7567 RAM Replacement: étape 6, image 1 de 1
    • Pull the battery towards you.
    • Make sure to pull at an upward angle.
  7. Dell Inspiron 15-7567 RAM Replacement, RAM: étape 7, image 1 de 2 Dell Inspiron 15-7567 RAM Replacement, RAM: étape 7, image 2 de 2
    • Remove the 3mm screw on the back using a Phillips #1 screwdriver.
  8. Dell Inspiron 15-7567 RAM Replacement: étape 8, image 1 de 2 Dell Inspiron 15-7567 RAM Replacement: étape 8, image 2 de 2
    • Remove the panel by lifting up the side towards you
  9. Dell Inspiron 15-7567 RAM Replacement: étape 9, image 1 de 2 Dell Inspiron 15-7567 RAM Replacement: étape 9, image 2 de 2
    • Release the two clips on the left and right side, by pushing outward on the side towards you.
    • The RAM strip will extend out. Pull towards you at a slight angle.
James Bedortha
Membre depuis le 09/28/18
97 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 22
Total : 790
