Aller au contenu principal
Dell Inspiron 1501 Memory Modules Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 1501 Memory Modules Replacement, Turn the Computer Over: étape 1, image 1 de 1
  2. Dell Inspiron 1501 Memory Modules Replacement, Loosen the Screws: étape 2, image 1 de 1
    • Loosen the two captive screws on the memory module/modem cover and remove the cover.
  3. Dell Inspiron 1501 Memory Modules Replacement, Popping up the Memory Module: étape 3, image 1 de 1
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the securing clips that secure the memory module.
    • NOTICE: Handle memory modules by their edges, and do not touch the components on a module.
  4. Dell Inspiron 1501 Memory Modules Replacement, Popping up the Memory Module: étape 4, image 1 de 1
    • Remove the module from the connector at a 45-degree angle.
  5. Dell Inspiron 1501 Memory Modules Replacement, Align the Notch: étape 5, image 1 de 1
    • Align the notch in the module edge connector with the tab in the connector slot.
  6. Dell Inspiron 1501 Memory Modules Replacement, Sliding the Module: étape 6, image 1 de 1
    • Slide the NEW module firmly into the slot at a 45-degree angle, and lower the module until it clicks into place. If you do not feel the click, remove the module and reinstall it.
  7. Dell Inspiron 1501 Memory Modules Replacement, Replace the Modem Cover: étape 7, image 1 de 2 Dell Inspiron 1501 Memory Modules Replacement, Replace the Modem Cover: étape 7, image 2 de 2
    • Replace the memory module/modem cover and tighten the captive screws.
    • NOTICE: If the memory module/modem cover is difficult to close, remove the module and reinstall it. Forcing the cover to close may damage your computer.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 555 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 323
