Aller au contenu principal
Dell Inspiron 1520 Display Assembly Replacement
Ce dont vous avez besoin
    • Follow the instructions in Before You Begin.
    • Close the display and turn the computer over.
  1. Dell Inspiron 1520 Display Assembly Replacement, Loosen the Screws: étape 2, image 1 de 2 Dell Inspiron 1520 Display Assembly Replacement, Loosen the Screws: étape 2, image 2 de 2
    • Loosen the two captive screws that secure the Mini Card compartment cover, then remove the cover and set it aside.
  2. Dell Inspiron 1520 Display Assembly Replacement, Remove the Screws: étape 3, image 1 de 2 Dell Inspiron 1520 Display Assembly Replacement, Remove the Screws: étape 3, image 2 de 2
    • Remove the two M2.5 x 8-mm screws from the bottom of the computer.
  3. Dell Inspiron 1520 Display Assembly Replacement, Remove the Screws: étape 4, image 1 de 1
    • Remove the two M2.5 x 8-mm screws from the back of the computer.
  4. Dell Inspiron 1520 Display Assembly Replacement, Disconnect the Display Cable: étape 5, image 1 de 1
    • Loosen the captive grounding screw, then disconnect the display cable from the display cable connector on the system board.
  5. Dell Inspiron 1520 Display Assembly Replacement, Disconnect the Connector: étape 6, image 1 de 1
    • Disconnect the camera/microphone cable from the camera/microphone cable connector on the system board.
  6. Dell Inspiron 1520 Display Assembly Replacement, Lifting the Display Cable: étape 7, image 1 de 2 Dell Inspiron 1520 Display Assembly Replacement, Lifting the Display Cable: étape 7, image 2 de 2
    • Lift the display cable and antenna cables from beneath the tabs on the palm rest.
    • NOTICE: Ensure that the display cable and the antenna cables do not get caught beneath the plastic tabs on the palm rest.
  7. Dell Inspiron 1520 Display Assembly Replacement, Lifting the Display Assembly: étape 8, image 1 de 1
    • Lift the display assembly out of the computer.
    • Align the display hinges with the holes in the base of the computer, then lower the display into place.
  8. Dell Inspiron 1520 Display Assembly Replacement, Sliding the Antenna Cables: étape 10, image 1 de 1
    • Slide the antenna cables through the hole in the palm rest and the base of the computer.
    • NOTICE: Ensure that the display cable and antenna cables are properly routed and secured beneath the plastic tabs on the palm rest.
  9. Dell Inspiron 1520 Display Assembly Replacement, Routing the Display Cable: étape 11, image 1 de 1
    • Route the display cable and antenna cables beneath the plastic tabs on the palm rest.
  10. Dell Inspiron 1520 Display Assembly Replacement, Connecting the Cables: étape 12, image 1 de 1
    • Connect the camera/microphone cable to the camera/microphone cable connector on the system board.
  11. Dell Inspiron 1520 Display Assembly Replacement, Connect the Display Cable: étape 13, image 1 de 1
    • Connect the display cable to the display cable connector on the system board.
  12. Dell Inspiron 1520 Display Assembly Replacement, Replace the Screw: étape 14, image 1 de 1
    • Replace and tighten the captive grounding screw.
  13. Dell Inspiron 1520 Display Assembly Replacement, Replace the Screws: étape 15, image 1 de 1
    • Replace the two M2.5 x 8-mm screws on the back of the computer.
  14. Dell Inspiron 1520 Display Assembly Replacement, Replace the Screws: étape 17, image 1 de 2 Dell Inspiron 1520 Display Assembly Replacement, Replace the Screws: étape 17, image 2 de 2
    • Replace the two M2.5 x 8-mm screws on the bottom of the computer.
    • Replace the Mini Card compartment cover and tighten the screws.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 555 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 10
Total : 481
