Aller au contenu principal
Dell Inspiron 1521 DVD Drive Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 1521 DVD Drive Replacement, Battery: étape 1, image 1 de 1
    • Rotate the laptop so its bottom is facing up.
  2. Dell Inspiron 1521 DVD Drive Replacement: étape 2, image 1 de 3 Dell Inspiron 1521 DVD Drive Replacement: étape 2, image 2 de 3 Dell Inspiron 1521 DVD Drive Replacement: étape 2, image 3 de 3
    • Identify the lock mechanisms holding the battery in place.
    • Slide each button outward with your fingers to disengage the battery.
    • Pull the battery off with your hand to separate it from the laptop.
  3. Dell Inspiron 1521 DVD Drive Replacement, DVD Drive: étape 3, image 1 de 2 Dell Inspiron 1521 DVD Drive Replacement, DVD Drive: étape 3, image 2 de 2
    • Locate the 4 mm Phillips #1 screw next to the white padlock image that holds the DVD drive in place.
    • Remove this screw with a Phillips #1 screwdriver.
  4. Dell Inspiron 1521 DVD Drive Replacement: étape 4, image 1 de 3 Dell Inspiron 1521 DVD Drive Replacement: étape 4, image 2 de 3 Dell Inspiron 1521 DVD Drive Replacement: étape 4, image 3 de 3
    • Use a plastic opener tool to carefully pry the DVD drive out of its pocket on the side of the laptop.
    • Once sticking out, pull the DVD drive the rest of the way out with your hand.
Rogelio Ordonez
Membre depuis le 09/26/12
54 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 15-47, Forte Fall 2012 Membre de l'équipe Cal Poly, Team 15-47, Forte Fall 2012
CPSU-FORTE-F12S15G47
5 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 12
Total : 1,029
