Aller au contenu principal
Dell Inspiron 1521 Keyboard Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 1521 Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Rotate the laptop so its bottom is facing up.
  2. Dell Inspiron 1521 Keyboard Replacement: étape 2, image 1 de 3 Dell Inspiron 1521 Keyboard Replacement: étape 2, image 2 de 3 Dell Inspiron 1521 Keyboard Replacement: étape 2, image 3 de 3
    • Identify the lock mechanisms holding the battery in place.
    • Slide each button outward with your fingers to disengage the battery.
    • Pull the battery off with your hand to separate it from the laptop.
  3. Dell Inspiron 1521 Keyboard Replacement, Keyboard: étape 3, image 1 de 3 Dell Inspiron 1521 Keyboard Replacement, Keyboard: étape 3, image 2 de 3 Dell Inspiron 1521 Keyboard Replacement, Keyboard: étape 3, image 3 de 3
    • Find the two small indentations of the sides of the panel covering the power button.
    • Pry up both sides of the panel by sticking the plastic opener tool in each indentation and prying up.
  4. Dell Inspiron 1521 Keyboard Replacement: étape 4, image 1 de 1
    • Now that the panel is loose simply pull the panel off with your hand.
  5. Dell Inspiron 1521 Keyboard Replacement: étape 5, image 1 de 3 Dell Inspiron 1521 Keyboard Replacement: étape 5, image 2 de 3 Dell Inspiron 1521 Keyboard Replacement: étape 5, image 3 de 3
    • Locate the two 5 mm Phillips #1 screws holding down the keyboard that were underneath the panel.
    • Remove these screws with a Phillips #1 screwdriver.
    • With the screws removed pull the keyboard up with your hand.
  6. Dell Inspiron 1521 Keyboard Replacement: étape 6, image 1 de 3 Dell Inspiron 1521 Keyboard Replacement: étape 6, image 2 de 3 Dell Inspiron 1521 Keyboard Replacement: étape 6, image 3 de 3
    • Locate the connector that links the keyboard to the laptop.
    • Gently pull the connector toward the screen of the laptop with your figers to disconnect it.
Nikolaus Powell
Membre depuis le 09/20/12
426 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 15-47, Forte Fall 2012 Membre de l'équipe Cal Poly, Team 15-47, Forte Fall 2012
CPSU-FORTE-F12S15G47
5 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 16
30 derniers jours : 22
Total : 2,123
