Aller au contenu principal
Dell Inspiron 1521 RAM Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 1521 RAM Replacement, Battery: étape 1, image 1 de 1
    • Rotate the laptop so its bottom is facing up.
  2. Dell Inspiron 1521 RAM Replacement: étape 2, image 1 de 3 Dell Inspiron 1521 RAM Replacement: étape 2, image 2 de 3 Dell Inspiron 1521 RAM Replacement: étape 2, image 3 de 3
    • Identify the lock mechanisms holding the battery in place.
    • Slide each button outward with your fingers to disengage the battery.
    • Pull the battery off with your hand to separate it from the laptop.
  3. Dell Inspiron 1521 RAM Replacement, RAM: étape 3, image 1 de 2 Dell Inspiron 1521 RAM Replacement, RAM: étape 3, image 2 de 2
    • Locate the Phillips #1 screw securing panel M.
    • Remove the screw from panel M with a Phillips #1 screwdriver.
  4. Dell Inspiron 1521 RAM Replacement: étape 4, image 1 de 3 Dell Inspiron 1521 RAM Replacement: étape 4, image 2 de 3 Dell Inspiron 1521 RAM Replacement: étape 4, image 3 de 3
    • Pry the panel open with the plastic opening tool.
    • Gently pull with your fingers to remove the panel.
  5. Dell Inspiron 1521 RAM Replacement: étape 5, image 1 de 3 Dell Inspiron 1521 RAM Replacement: étape 5, image 2 de 3 Dell Inspiron 1521 RAM Replacement: étape 5, image 3 de 3
    • Identify the metal tabs holding the RAM in place.
    • Gently press outward on the tabs at the same time with your fingers to release the RAM.
    • Gently pull the RAM outward with your fingers to remove it.
Nikolaus Powell
Membre depuis le 09/20/12
426 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 15-47, Forte Fall 2012 Membre de l'équipe Cal Poly, Team 15-47, Forte Fall 2012
CPSU-FORTE-F12S15G47
5 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 20
30 derniers jours : 29
Total : 3,429
